1 vlan is not working, why?? Help
My core has created 10 vlans, my edge switch learn all of them through the trunk link. But there is 1 vlan not working at all. servers place in this VLAN is not pingable to core layer 3 interface, servers are not pingable to other servers within same vlan as well. So i suspect its a layer 2 problem.
when i do a show vtp status on the problematic edge switch:
MOM-SVR5#sh vtp statius us
VTP Version : 2
Configuration Revision : 33
Maximum VLANs supported locally : 1005
Number of existing VLANs : 18
VTP Operating Mode : Client
VTP Domain Name : MOMSVRFM
VTP Pruning Mode : Enabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x8E 0x30 0x39 0x41 0xAD 0x49 0x62 0x4E
Configuration last modified by x.x.x.x at ^@^@:^@^@:^@^@
the date shows funny charactor which i suppose corruption to the vlan.dat file.
After i delete the file, when it relearn the VTP info and construct a new VLAN.dat. the problem still persists.
My solution is copy the vlan.dat from another similar model switch to this switch to resolve it.
But what causes it? any expert to advice??
Hall of Fame Super Bronze
Re: 1 vlan is not working, why?? Help
That's very odd, have you tried upgrading the switch's IOS version ?
__
Edison.
nope.. i didnt upgrade the IOS.
This problem just happend, its not like it has been there all along
Hi, I think you may have a IOS bug in your software, BUGS will sometime lay dormant in the IOS and then all of a sudden they will start causing problems. I agree with the previous post from Edison you might look into an IOS upgrade, also the switch you plan on coping the vlan.dat is it running the same IOS? is it having similar problems? I posted some link below that may help. HTH
http://www.cisco.com/kobayashi/sw-center/sw-ios.shtml
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.0.3/user/guide/bugtlkt.html
119
