10 GB Interface RCV Discards
I'm interested in what might cause RCV Discards on 10GB interfaces.
I'm speculating it may be related to buffer settings on the switch, but I'm looking into any and all possibilities to consider.
Re: 10 GB Interface RCV Discards
Can you get a 'show interface ' for the tengig intf you are talking about?
Discards can be because of buffer settings as you mentioned...this would have a lot to do with the traffic flow in your box. For example, if you have a steady stream of 9G in one port and out a 10G port, and then you burst some traffic in this interface, I would expect to see some discards. What will happen is the port-asic on the egress line card in this case may attempt to flow-control the ingress port asic over the fabric, which will cause it to buffer traffic until its buffers are full, at which point it will have no choice but to discard packets.
ovt Bronze
Bronze
If it is 8-port or 16-port card can the discards be caused by oversubscription between the card and the fabric?
What model of line card? There are plenty of 8 and 16 port modules. =)
That was a dumb question. If you are doing 10gig they have to be either 6708 or 6716. Both of those cards are oversubscribed on the fabric. Each fabric channel supports half the ports on the line cards and is a 20gig pipe.
ovt Bronze
Bronze
It's not my system :))) He mentioned 10-Gig module. But, in general, if it is 8-port 10-Gig, and lot of traffic is arriving, what will happen? How to diagnose oversubscription?
You would potentially see lots of input drops, and possibly buffer overruns as shown by show interfaces. You might also want to look at the transmitting side to see if there are output drops there.
Thanks for the replies. Here are more details.
WS-C6513 (R7000) processor (revision 1.0) with 458720K/65536K bytes of memory
CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE
TenGigabitEthernet11/4 is up
Input queue: 0/75/857/857 (size/max/drops/flushes); Total output drops: 0
AVG Transmit bps =20mbps Peaks to 40mbps
AVG Receive bps = 10mbps Peaks to 50mbps
Utilization on the 4 tengig ports remains well under 10%.
167
