10 Gbp Optics
I have a question around the choice of 10G XENPAK for a network design that I am working on.
I am installing several 6509-E chassis around a campus which will all be meshed via 10Gb trunks. The distances between the communication rooms varies from 50 metres to 200. The grade of the installed fibre is 50/125 micron - (OM2)
Am I correct in saying from the detail on this datasheet that Cisco XENPAK-10GB-SR will not be supported as they only do above 26 metres if the fibre is 62.5 OM3 ?
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet09186a008007cd00.html
I think the next XENPAK (Cisco XENPAK-10GB-LX4) will provide me with the distances needed given that changing the fibre is not an option ?
could someone confirm ?
much appreciated
Nathan
1 ACCEPTED SOLUTION
bjw Silver
Silver
Re: 10 Gbp Optics
Nathan,
Sounds like you're going the right direction. Here's a little MMF fiber slide show that seems to affirm your findings.
http://www.corning.com/docs/opticalfiber/cm4260.pdf
Good Luck
bjw Silver
Silver
Re: 10 Gbp Optics
Nathan,
The 10GB-SR module will light up to 300m on 50/125um OM3 grade fibre. If you can verify that you're fiber is OM3 then it should work as advertised.
The 10GB-LX4 would be used if you had only 62.5/125 MMF
Bill
Re: 10 Gbp Optics
Bill,
Thanks for your response but this is the issue I have. The fibre installed is 50/125 OM2 not OM3.
The Max distance of fibre is 200 metres so going by the stats the SR looks like it will not cut the mustard, whereas LX4 looks to provide further distances on lower grade fibre
I must admit that I have not done much work with 10Gbp connectivity and if I have then it has been short distances within the same comms room.
bjw Silver
Silver
Re: 10 Gbp Optics
Nathan,
Good Luck
Re: 10 Gbp Optics
Thanks Bill,
That slide show does confirm what I was thinking , good to get things double checked :)
Cheers
Re: 10 Gbp Optics
Double Post
170
