11-18-2011 03:21 AM - edited 03-07-2019 03:28 AM
Can anyone confirm if a 10Ge interface can be set down to 1Ge if required ?
(speed)
11-18-2011 03:39 AM
hi chris,
i'm afraid not.
7606(config)#int te2/2
arc005(config-if)#s?
sap-priority service service-policy shutdown smrp
sna snapshot snmp source spanning-tree
stack-mib standby storm-control switchport sync-restart-delay
7606(config-if)#sp?
spanning-tree
11-18-2011 03:41 AM
There are Interfaces that you can use both 1 gig or 10 gig sfp in.
There are other interfaces that you can only use 10Gig sfp in.
So it depends on what equipment and where the port is located.
FX the Nexus 5000 has some ports that are both 1/10gig sfp compatible and some ports that are only 10gig compatible in the same unit.
The 3750x C3KX-NM-10G has 4 SFP ports that you either can use 2 10Gig or 4 1gig or 1 10gig and 2 1gig.
So the answer is we do not know.
We lack the information needed to tell you if the equipment you are thinging about is possible to change speed between 1 and 10 gig.
If you tell us the hardware you are thinking about then we might be able to help you to a better answer.
Good luck
11-18-2011 05:19 PM
NO.
11-19-2011 04:58 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If the 10 gig interface supports SFP+ it can support gig or 10 gig. Actual SFP transceiver module would determine supported bandwidth. Except for the 10/100/1000 copper transceiver module, transceiver will generally only support one bandwidth.
