10-06-2009 12:01 AM - edited 03-06-2019 08:00 AM
I installed a GLC-FE-100BX-U transceiver
in a C2960-8TC-L switch running the latest IOS, but the interface doesn't come up.
Do I have to configure 100M sfp support somehow?
sh int shows "media type is 1000BaseLX SFP" at the moment.
10-06-2009 12:29 AM
Hello Alex,
have you placed the companion type of SFP on the other side of the link?
see
no special settings are needed and sh int type x/y should report the right SFP type
example
sh int gi0/25 | inc SFP
Full-duplex, 100Mb/s, link type is auto, media type is 100BaseFX SFP
this is from a 3560
in the link your model is not listed among the ones supporting 100M SFPs see table of supported models
Hope to help
Giuseppe
10-06-2009 12:55 AM
Yes, I have tested the sfp in another (non Cisco) switch, and there it works fine.
The WS-C2960-8TC-L/GLC-FE-100BX-U combination is listed in:
10-06-2009 03:33 AM
If these are dual media type ports you may have to specify SFP instead of RJ45 .
10-06-2009 05:02 AM
I have tried both media type "auto-select" and "sfp" configurations.
1000M SFP:s work fine in the switch.
Oddly enough, the switch in the other end of this connection shows link up on the port connected to the 2960.
