Community Member
10G line card on Cisco Catalyst6509
hi,
Urgent help need
I got one cisco catalyst 6509. As a new project in, i need to add 10G fibre card to install on.
AS the Supervisor engine version is as the following
1000BaseX Supervisor      WS-X6K-SUP2-2GE
in addition, i get MSFC2 card in the box,
I checked the doc about Catalyst6500 10G card module data sheet, I found the supported supervisor engine is 720.
could someone is able to help to confirm whether my box support 10G fibre card or not?
Thank you very much!
1 ACCEPTED SOLUTION
Highlighted
Community Member
Re: 10G line card on Cisco Catalyst6509
As per the datasheet for 10Gig cards for 6500, they are supported only on Supervisor Engine 720
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a00801dce34.html
1 REPLY
Highlighted
Community Member
1516
