Webcast-Catalyst9k
12.2(25)EWA7 bugs
Does anyone know if there are significant bugs with IOS release 12.2(25)EWA7 and Spanning-tree protocol?
I am having problems with loops and have ruled out most other possibilites.
Thanks.
Silver
Re: 12.2(25)EWA7 bugs
Hello. Try using bug toolkit:
http://tools.cisco.com/Support/BugToolKit/
you can search for bugs associated with your image.
Hope this helps
Purple
None that I know of and we have quite few 4500's with code around that same release.
Hi ,
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsh25687
This is very impacting bug in the release.
According to my experience, this version is to be avoided.
You may notice many problems, including SPT loops.
I recommend to upgrade.
regards
Gregory
Thanks for the reply.
it does look suspicious. I am implementing BPDU Guard anyway and LoopGuard on all the trunk ports, but also plan to upgrade the IOS in addition just to be sure.
Its a strange one as it happens infrequently and seemingly without any obvious cause.
Mike
180
