12.2(50)SE Bug ?
Not sure if this is a bug or a new feature ?
switchname(config)#enable secret 5 XXXXXXXXXXXXXX (encrypted password)
ERROR: The secret you entered is not a valid encrypted secret.
To enter an UNENCRYPTED secret, do not specify type 5 encryption.
When you properly enter an UNENCRYPTED secret, it will be encrypted.
Hope that this is a bug, but have anybody else a fix for this problem ?
cut & paste of old config doen't work any longer. :-(
Hall of Fame Super Silver
Re: 12.2(50)SE Bug ?
Hello Roar,
the message says to use
enable secret
I would so and I would leave to the device to create the encrypted version of the secret
these are the options
enable secret ?
0 Specifies an UNENCRYPTED password will follow
5 Specifies an ENCRYPTED secret will follow
LINE The UNENCRYPTED (cleartext) 'enable' secret
Hope to help
Giuseppe
Hall of Fame Super Gold
This is probably an "undocumented feature". I can't even see this command anymore in the 12.2(50)SE Switch Command Reference.
Typing the enable secret and the appliance will automatically encrypt it event though the "no service password-encrypt" is available. See below:
enable secret 5 $1$TZVm$SSMOghMN0RymiQKxNfmUC.
enable password juniper
Not good.
Bronze
Service password-encryption has nothing to do with any "secret" passwords. They are automatically shown hashed MD5 output.
Service password-encryption only encrypts clear text passwords utilizing the "password 7" cipher (Vigenere). The passwords are not "encrypted". They are obfuscated to keep people from shoulder surfing.
You can get the crypts in by partial config file transfer via tftp/scp, and they still work from flash. It's just from the commandline that this is borked.
This appears to be a new bug that has not been fixed yet.
The bug is CSCsy24510: IOS no longer accepts encrypted password / secret
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsy24510
Hi Erich,
Thanks for point us to the right direction. +5
I've just confirmed that 12.2(50)SE1 has fixed this bug. I was finally able to paste in my encrypted secret passwords from the command-line. I'm glad I found this thread, because I was banging my head against the wall.
Hello there,
I am not sure which version of IOS you're running but, this indeed looks like the bug I pointed out.
CSCsy24510 IOS no longer accepts encrypted password / secret
It is fixed in 12.2(50)SE1.
Oops,
Still learning the NetPro tool. Glad to know that your problem is fixed.
Just to summarize, this bug is fixed in 12.2(50)SE1.
402
