1252 trunk default vlan route to radius
I have in place switching with both static and dynamic vlans (dynamic is done by radius). I have another vendors wirless equipment and it is working fine in this setup. I can not get my 1252 WAPS working tho. My 1252 GigabitEthernet0 interface is plugged into a trunked switch port allowing all vlans (tagged). No vlans are untagged on this port except vlan 1 (native).
Below is my 1252 config, There are two issues:
1. I can not manage/ping the web interface which is on vlan 10, subnet 10.148.198.x. I only want to be able to manage the switch from vlan10 and its subnet. Vlan1 should have no management abilities.
2. Clients trying to connect to ssid BSC cannot auth with the radius server. I beleive the 1252 cant contact the radius server because it is on vlan 10. How do I tell the 1252 to go out GigabitEthernet0 interface tagged on vlan10 to find the radius server? Is there a command for a default vlan route before clients auth?
3. In my config is theGigabitEthernet0 interface correctly configured as a trunk allowing all vlans (tagged)? Vlan1 shouldn't be tagged.
version 12.4
no service pad
service password-encryption
hostname ip54
enable secret 5 $1$zH/A$
enable password 7 1404430
aaa new-model
aaa group server radius rad_eap
server 10.148.198.47 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip domain name domain1
dot11 vlan-name BSC vlan 10
dot11 vlan-name DEF vlan 1
dot11 vlan-name PRT vlan 50
dot11 vlan-name ROUGE vlan 20
dot11 ssid BSC
vlan 1
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa version 2
mbssid guest-mode
dot11 ssid vlan10
vlan 10
authentication open
mbssid guest-mode
wpa-psk ascii 7 04574hjgh
power inline negotiation prestandard source
username Cisco privilege 15 secret 5 $1$1mmmh
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
encryption mode ciphers aes-ccm
encryption vlan 10 mode ciphers aes-ccm
encryption vlan 20 mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 50 mode ciphers aes-ccm
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio0.50
encapsulation dot1Q 50
no ip route-cache
bridge-group 50
bridge-group 50 subscriber-loop-control
bridge-group 50 block-unknown-source
no bridge-group 50 source-learning
no bridge-group 50 unicast-flooding
bridge-group 50 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid BSC
ssid vlan10
no dfs band block
mbssid
channel 5765
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.10
no ip route-cache
bridge-group 10
interface Dot11Radio1.20
no ip route-cache
bridge-group 20
interface Dot11Radio1.50
no ip route-cache
bridge-group 50
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.10
no ip route-cache
bridge-group 10
interface GigabitEthernet0.20
no ip route-cache
bridge-group 20
interface GigabitEthernet0.50
no ip route-cache
bridge-group 50
interface BVI1
ip address 10.148.198.54 255.255.254.0
no ip route-cache
ip default-gateway 10.148.198.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.148.198.47 auth-port 1812 acct-port 1813 key 7 143517070
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
Re: 1252 trunk default vlan route to radius
HI ,
You did not map the BVI right.
The correct configuration need to look:
no ip route-cache
bridge-group 11               Just an example
no bridge-group 11 source-learning
bridge-group 11 spanning-disabled
no ip route-cache
bridge-group 1               Now VLAN 10 is mapped to BVI1 with you IP for managing and Radius communication
If you want to be able to manage the AP via Wireless you need to change the interfaces in the same way.
But maybe you are not able to change the BVI ot Interface 0.1 so I would recommend to change the config and upload the hole one new.
- Sebastian
Thanks for the reply. I changed the config to make all three 0.1 sub interfaces bridge-group 11 and all three 0.10 sub interfaces bridge-group 1. This made it so I can manage via 10.148.198.x and also made the radius server contactable by the AP Thanks!
However, a major problem still exists: When I go on any vlan client with radius they seem to associate but not get dhcp. There is a DHCP on each subnet/vlan. This setup is working with my other wireless vendor. Also if the radius server assigns vlan 10 to a client the connecting wireless dialog in WinXP speeds up but never connects. In the 1252 web page I can see that radius has assigned it to the correct vlan based but no DHCP. There is still a major config issue and I beleive it has to do with the vlans and bvi etc. If I set an SSID without radius and (eg the ssid called vlan10) it works fine!
Thanks again.
300
