11-11-2006 10:56 PM - edited 03-05-2019 12:45 PM
Hi all
When i configuer my 1721 router, I got this error when I configuerd Ethernet interfaces please help :-
*Mar 1 03:03:25.927: %PQUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceive
r problem?
11-11-2006 11:34 PM
Hello Ahmed,
this is not really an error, it just tells you that there is nothing physically connected to your Ethernet interface. As soon as you connect another device to that Ethernet interface, the message will disappear. You can also get rid of it by configuring the interface with the 'loopback' interface command, which puts the interface into up/up status...
HTH,
GP
11-13-2006 03:25 AM
Hello GP
I don't know how thank you, but realy thanks a lot, this gift for you, please visit this site and may you read this article
http://discover.islamway.com/articles.php?article_id=20
Ahmed
11-11-2006 11:45 PM
this is because that your ethernet cable is unplugged & thatz the reason you get this message. try connecting this ethernet cable on to the router.
hope this helps.
rate this post if cleared.
11-12-2006 01:21 AM
Hi ,
The error message, %PQUICC_ETHER-1-LOSTCARR - means that the Ethernet 10BASE-T cable is unplugged, so it is better to check if the cable was loosened or is unplugged.
***** Recommended Action:Reconnect the 10BASE-T Ethernet cable.If the cable is not unplugged might i suggest that you check the integrity of your cables.Means check whether cable is plugged in the correct interface or not.
hope it helps you.
satish
