Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
1711 - ios 12.3 - dhcpv6 not operating
hi
i am trying to set dhcpv6 in cisco router 1711 with ios 12.3.
my first question does dhcpv6 is supported in this ios
second i can see that my device sends dhcpv6 request but the router respond with icmpv6 neighbor solicitation.
thanks
for the help
router running conf :
Router#show running-config
Building configuration...
Current configuration : 1501 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$Mm9c$X2dAko9L0njvDSQ52Hdcf1
enable password 1234
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
ip ips po max-events 100
ip multicast-routing
ipv6 dhcp pool pool1
prefix-delegation 2001:DB8:1263::/48 0005000400F1A4D70D03
prefix-delegation pool prefix-pool
dns-server 2001:DB8:3000::42
domain-name test1.com
no ftp-server write-enable
interface FastEthernet0
ip address 192.168.10.228 255.255.255.0
ip pim sparse-dense-mode
no ip route-cache
ip igmp version 3
ip igmp querier-timeout 60
ip igmp unidirectional-link
ip igmp proxy-service
speed auto
full-duplex
ipv6 dhcp server pool1
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface FastEthernet4
no ip address
shutdown
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Async1
no ip address
no ip route-cache
ip classless
no ip http server
no ip http secure-server
ip pim rp-address 192.168.10.228 5
snmp-server community public RO
control-plane
line con 0
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password 1234
login
end
244
