Community Member
1721 and t1
I've a 1721 cisco router and I need to purchase to my ISP (Telefonica Spain) a point to point conection to internet.
What kind of wic have I need to purchase?
best regards
1 ACCEPTED SOLUTION
Re: 1721 and t1
Hi Edgar
since its a point to point (T1) link its limited only to 1.5 Mbps you can make use of that 1.5 Mbps bandwidth alone.
you wont be able to add or remove any channels on this module.
if you want to upgrade the existing bandwidth from 1.5 Mbps then you will have to add up one more module or go with WIC-2T and 2*T1's which can support 2*1.5Mbps ..
regds
Re: 1721 and t1
Hi Edgar
you can go ahead with WIC-1T card for this connectivity.
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00801f5d87.shtml
regds
Community Member
Re: 1721 and t1
Hw many channels are reserved for a 1t connection? if I add more channels, will this card be enough?
best regards
Re: 1721 and t1
Hi Edgar,
WIC-1T supports maximum of 2Mbps bandwidth.
Re: 1721 and t1
Hi Edgar
regds
Community Member
Re: 1721 and t1
This wic card is available for 1721?
Re: 1721 and t1
Hi Edgar
do check the link posted in my first post..
regds
Community Member
Re: 1721 and t1
Examples for this wic with 1721?
129
