Community Member
1751 Router Hang after upgrade IOS
Dear Friend,
plz help me i have upgrade IOS on cisco 1751
upgradet version c1700-k9sv8y7-mz.122-15.T14.bin
but problem with Router is hang and Router is Stop on below menstion step kinldy help me
Router#copy tftp flash:
Address or name of remote host [172.16.10.220]?
Source filename [c1700-k9sv8y7-mz.122-15.T14.bin]?
Destination filename [c1700-k9sv8y7-mz.122-15.T14.bin]?
Accessing tftp://172.16.10.220/c1700-k9sv8y7-mz.122-15.T14.bin...
Erase flash: before copying? [confirm]
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ...erased
Erase of flash: complete
Loading c1700-k9sv8y7-mz.122-15.T14.bin from 172.16.10.220 (via FastEthernet0):
[OK - 13162668 bytes]
Verifying checksum...  OK (0xE7EE)
13162668 bytes copied in 161.580 secs (81462 bytes/sec)
Router#relo
Router#reload
System configuration has been modified. Save? [yes/no]: y
Building configuration...
[OK]
Proceed with reload? [confirm]
*Mar  1 18:37:26.391: %SYS-5-RELOAD: Reload requested by console. Reload Reason:
Reload Command.
System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 2001 by cisco Systems, Inc.
C1700 platform with 32768 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0xc8d7b8
Error : memory requirements exceed available memory
Memory required     : 0x021A7F7C
*** System received a Software forced crash ***
signal= 0x17, code= 0x4, context= 0x0
PC = 0xbaddaddd, Vector = 0xbaddaddd, SP = 0xbaddaddd
*** Machine Check Exception ***
PC = 0xfff16784, Vector = 0x200, SP = 0x81fffe28
Hall of Fame Super Gold
You're trying to load an IOS which your DRAM can't accomodate.
Look for another IOS version which will fit your appliance's DRAM and memory.
Community Member
but i am not able to give any commond on router becoz Router is hang on
this step
Purple
The new IOS needs more RAM to be decompressed, you need 96 MB of RAM for this image.
Alain
Community Member
how can re intall IOS if the router hang on
and Router is not going Rommon mode amd # mode
Purple
power cycle then go to ROMMON  and use tftpdnld to install a valid image.
alain
Community Member
power cycle ? it meens reset the power
Community Member
how to gorommon mode
Community Member
Router is Hang
Community Member
Router us not taken any commond
Community Member
i have use Ctrl-Break key for the go rommon  mode but its not working
Community Member
Purple
have you shut it down then unshut( power cycle)  ? before using the ctrl-break ?
Alain
292
