1841 Config
I'm not sure if this is the right place to post, but I can't seen to find the answer after several hours of searching online.
I'm working with an 1841 router with 2 ethernet ports. What I want to do is to set them to foward packets back and forth. This has to be bi-directional, so a gateway of last resort will probably not be feasible.
Any suggestions or hints about how to configure this?
Re: 1841 Config
You need to have proper routing defined on the router so that the traffic can move to and fro.
regds
Re: 1841 Config
By default the router will route between the directly connected subnets, as it knows how to get to them both.
106
