1841 - no outside connection
sp0000003
I've got a (lab) 1841 router, that wont connect to the outside(internet)
Cannot ping 8.8.8.8 from router
My config is
Current configuration : 1005 bytes
version 12.4
service config
hostname Cisco1841
boot-start-marker
boot-end-marker
! card type command needed for slot 0
no logging console
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip nat inside source list 10 interface FastEthernet0/0 overload
access-list 10 permit 192.168.0.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
end
####################3
Cisco1841(config)# do sho ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            10.111.131.253  YES DHCP   up                    up
FastEthernet0/1            192.168.0.1     YES manual up                    down
NVI0                       unassigned      YES unset  up                    up
2 Accepted Solutions
I suspect that the issue has to do with the static default route.
When you configure a static route pointed at an Ethernet interface it requires that the next hop router has enabled proxy arp. And increasingly providers are not enabling proxy arp (because of the security implications). I suggest that you change your static default route to this and tell us if it works better.
ip route 0.0.0.0 0.0.0.0 dhcp
Rick
Rick
As Richard already explained a static route pointing out a multipoint ethernet interface cannot work if the next-hop is not implementing proxy-arp because the router will arp for the destination address instead of the next-hop address believing it is located out the multipoint interface and if the nexst-hop is implementing proxy-arp AND knows about the destination then it will reply on its behalf.
ip route 0.0.0.0 0.0.0.0 will set the next-hop as the default-router advertised by DHCP and will set the AD to 1 but this is not mandatory to explicitly configure a static route in this case as the router should install one automatically to the default-router IP with an AD of 254.
Alain
6 Replies 6
Reza Sharifi
Why is interface fa0/1 down?
Is there anything connected to this interface?
Rick
Rick
Nothing is connected to fa0/1, cause I havn't connected my pc (but it works)
Will try the new static route, later to day, but what is the difference between
ip route x.x.x.x x.x.x.x interface
and
ip route x.x.x.x x.x.x.x dhcp
Alain
sp0000003
Thanks a million
I am glad that our responses provided an explanation of your problem. Thank you for using the rating system to mark this question as answered. It makes the forum more useful when people can read about a problem and can know that a solution was found. Your marking has contributed to this process.
Rick
Rick
