Community Member
1841 router, not translating addresses
Hello, I have an 1841 router, with a wic card. Users on this router connect out to the net through pppoe on fa0/1/dialer1, and the internal lan is network.
2 of the machines on that lan won't browse to certain sites.,, etc.
When i look at the show ip nat trans for two machines going to the same addy, for this test, Machine 1 is successfull and has around 13-14 translations. Machine 2 has 2 translations and sits there like a lump waiting on the page to respond.
Just to clear up any spyware/virus suspicions. Unsuccessfull machine is a fresh install of win2kserver. nothing on it but the OS.
Here is a show ip nat trans with those two machines trying to get to .11.4 being the failed one.
Pro Inside global Inside local Outside local Outside global
tcp x.x.x.x:1227
tcp x.x.x.x:2494
tcp x.x.x.x:2495
tcp x.x.x.x:2496
tcp x.x.x.x:2497
tcp x.x.x.x:2498
tcp x.x.x.x:2499
tcp x.x.x.x:2501
tcp x.x.x.x:2522
tcp x.x.x.x:2523
tcp x.x.x.x:2524
tcp x.x.x.x:2525
and heres the rest of the config.
S* is directly connected, Dialer1
interface FastEthernet0/0
ip address
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname XXXXXXXXX
ppp chap password 0 XXXXXXX
no ip http server
ip nat inside source list 1 interface Dialer1 overload
Standard IP access list 1
10 permit, wildcard bits log (1080 matches)
any ideas? and thanks if you do.
Community Member
Re: 1841 router, not translating addresses
One reason could be number of ip addresses are not sufficient.If you are unable to browse only specific websites try adjusting the is a secure site so make sure in the IE the cipher strength is 128 bits.
