Community Member
1841 Router - SDM - Insatll Wireless Application
I have a Cisco 1841 integrated services router with wireless built-in. I am attempting to use SDM to configure the wireless, but when I click the 'Wireless Application' button it says I have to install it on the router first. I am running SDM Version 2.5 which is the latest version from Cisco. I cannot find where to get the 'wireless application' to load. Anybody got any ideas?
1 REPLY
Bronze
Re: 1841 Router - SDM - Insatll Wireless Application
Look for a file named: wlanui.tar. You should have it under the SDM installer you either downloaded or from the SDM CD. That file must ben in the flash of your router in order for you to be able to configure the wireless part via SDM.
Hope it helps...
401
