1841 VWIC 1MFT-T1 configuration
william.culver
It's been a while. I need to configure an interface for the T1 controller. Any help would be appreciated. I thought it was a virtual serial interface, but can't for the life of me get it going here. I am open to suggestions.
pstebner1
Hi William-
Assuming you have the framing and linecode, first you configure the controller:
Router(config)#controller t1 0/1
Router(config-controller)#framing esf
Router(config-controller)#linecode b8zs
Router(config-controller)#channel-group 1 timeslots 1-24
Then the serial interface:
Router(config-controller)#int s0/0:1
Router(config-if)#ip address xx.xx.xx.xx 255.255.yy.yy
(if it's a point-to-point):
Router(config-if)#encap ppp
Tha't about it. Let me know if you have any specific requirements that I didn't cover.
HTH,
Paul
It's all coming back. I think that should do it. Will know for sure when the line gets turned up tomorrow. Appreciate the help.
hi its not necessarily be encap PPP on point to point interface. Even if u dont do the
encap PPP command the link shud come up.
If you do encap PPP, you need to do it on the remote end of the link too...
Cheers!
