Community Member
1861 CUE 3.0.3 Update
For the UC500 you can get the new 4.2.7 software which includes the CUE 3.0.3 update. Where do I get the update for the Cisco 1861 Router? Where do I get the CUE language files for the 1861 Router?
1 REPLY
Silver
Re: 1861 CUE 3.0.3 Update
The 1861 doesn't use an NM, NME, or AIM for the CUE. Its a different type of module, the same one that is in the UC520. This means you can't use the nm-aim or NME install images. The image is available for the UC520.
You can download from the Below URL :
http://www.cisco.com/cgi-bin/tablebuild.pl/UC520-CUE-2.3.4
158
