1941 W Configuration Router to Embedded AP
     The problem that I am having with my configuration is being able to route between the Router and its embedded WLan-AP.  I am looking into configuring the Wlan-G0 interface in the Router to communicate with the GE0 interface in the embedded WLan-AP allowing the devices to route between Devices. Bellow is the configuration of the Device.  Any help is welcome.
******** WLAN_AP *******
hostname BAY02_AP
enable secret 5 $1$jOkE$TjxX0XA0CyA6bz2qwz6Fq/
enable password 7 072C285F4D06
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.120 192.168.2.126
ip dhcp pool WLAN_BAY02_USERS
   network 192.168.2.64 255.255.255.192
   default-router 192.168.2.126
   lease 55
dot11 syslog
dot11 ssid BAY_BRIDGE
   authentication open
   authentication key-management wpa version 2
   infrastructure-ssid
   wpa-psk ascii 7 BAY_NASAMars_2013!
username Cisco password 7 00271A150754
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
channel 2437
station-role root bridge
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
description To 1941AP03 Dot11Radio1 Bridge
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid BAY_BRIDGE
antenna gain 0
dfs band 3 block
channel dfs
distance 1
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
interface BVI1
description Bridge Interface IP Address
ip address 192.168.23.2 255.255.255.240
no ip route-cache
ip default-gateway 192.168.22.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no activation-character
line vty 0 4
login local
end
******** Router Config ************
hostname BAY02_RT
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip cef
license udi pid CISCO1941W-A/K9 sn FTX140980LH
hw-module ism 0
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description To 3750 Gig1/0/24 LAN Hosts
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
description To L2 Cisco Switch For Routers
ip address 192.168.123.2 255.255.255.248
duplex auto
speed auto
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
ip address 192.168.22.1 255.255.255.240
bridge-group 1
interface BVI1
no ip address
interface BVI2
mtu 1514
ip address 10.0.23.2 255.255.255.248
interface BVI23
ip address 192.168.23.1 255.255.255.240
router eigrp 123
network 192.168.2.0
network 192.168.4.0 0.0.0.7
network 192.168.23.0 0.0.0.15
network 192.168.123.0 0.0.0.7
ip forward-protocol nd
no ip http server
control-plane
bridge 1 route ip
bridge 23 protocol ieee
bridge 23 route ip
line con 0
line aux 0
line 2
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Romieo
Thanks, Romieo
Hall of Fame Super Gold
Go here.
There are some recently-attached router config for the 880W.  The config should work with you.
Thanks for the suggestion Leo.  I looked over the discussion but I found what I needed to add in my configuration after looking into deeper.  If there is anyone with the same issue Reading this posting looking into your Bridging configuration.
Router configuration:
1st Configure the Wlan-G0/0 port as a trunk. Configure your Native Vlan.
2nd Configure the Native Vlan to the Bridge-group of the BVI interface.
3rd Make sure the BVI interface is in the same subnet as the BVI interface on the embedded AP.
Embedded WLan-AP configuration:
1st Configure the G0 Interface with a sub-interface G0.X as a Dot1q Native Vlan.
2nd Configure the Sub-interface as part of the Bridge-group on the AP side of the Router.
3rd Remember that the only Bridge-group on the WLan-AP that supports Routing IP is Bridge 1
*** Note:  Bridge 1 protocol ieee
                     Bridge 1 route ip (Most important command for bridging to work)
Romieo
If this Helps don't forget to Rate.
Thanks, Romieo
Not sure about the 1941 but BVI is found in the AP only.  So your router's management IP Address should be in the same subnet as the AP's BVI1 interface.
Yes, you can either configure the Management IP Address in the same Subnet, but I don't know if its the IOS on the 1941.  I had to create a BVI on the Router and place the VLan Interface into the Bridge-group.  It drove me crazy for about 4 days to figure it out But thats Networking.. Now I will never forget..
Romieo
Thanks, Romieo
Here are my simple problem >
Here are my simple problem >>
i need the radiod1 and 2 to give ip address ( 192.168.0.0 255.255.255.0 ) dhcp server will be handled by the router.
but they give ip address ( 255.255.0.0 range )
dot11 ssid Samplessidabg
auth open
auth key wpa ver 2
wpa-psk ascii password1
guest-mode
exit
dot11 ssid Samplessidn
auth open
auth key wpa ver 2
wpa-psk ascii password2
guest-mode
exit
int d0
encryp mode ciphers aes
ssid Samplessidabg
bridge-group 1
channel 6
no shut
exit
int d1
ssid Samplessidn
bridge-group 1
channel 6
no shut
exit
int bv1
ip address 192.168.0.2 255.255.255.0
ip nat inside
exit
default-gateway 192.168.0.1 ( also the gateway in my router w.c i have configures
correctly)
if anyone can help me what do i need to change or add in this config
or show a sample that works..
thanks for the help..
320
