1941W (or any ISR G2 Router) with 4esg ethernet configuration example
I have a very simple setup I am trying to get with my 1941W.
Gig0/0 is my WAN port tied to a Comcast Business connection - No issues
Gig0/1 is my internal LAN connection, private IP, dhcp - No issues
Gig0/1 is connected to a 24 port PoE switch via ethernet cable.
The switch connects to a Linksys E4200V2.
What I want to do is get rid of my big PoE switch (which is powering one phone) and my Linksys E4200v2 and use just the 1941W.
<mini-rant-on>
OK, I guess I am old school and like it when a router is a router and a switch is a switch.....
Unfortunately there is, from what I can tell, a complete lack of configuration examples.  I found many snippets and one entire configuration complete with ppt slides that does not actually work with the 1941W I have (the example shows Interface Gigabit0, while my 1941W has them listed as interface Gigabit0/0)
And I HATE asking for help.  I would much rather find a few working examples, read about any command I don't know about, and muddle through getting something to work:  It may not be secure or the 'best' way to do it, but they did work.
<mini-rant-off>
So, in my current setup everything is working:
Comcast Cable Gateway--->Static IP<--- Gig0/0 1941W--- 1941W Gig0/1 dhcp pool---PoE switch-------------Linksys E4200v2
        |---------------------PoE phone
        |------------computer, print server, etc.
And obviously I want the following:
Comcast Cable Gateway--->Static IP<--- Gig0/0 1941W----Gig0/1, Gig0/0/0 to Gig0/0/3--dhcp pool1----------->>>> to wired devices.
        1941W---wlan-gig0/0----accesspoint-------------------------------->>>> to wireless devices.
I would prefer to have my wireless and wired links share one DHCP pool, but they do not have to.  At this point I would take anything I can get.  I do have a working AP configuration from work that connects the AP to devices using WAP, allocating DHCP from a second DHCP pool but can't get the wireless to route outside the box.
I thought it was as simple as assigning a VLAN with a DHCP pool to the 4esg ethernet ports, but that does not quite work.  A computer plugged directly into 4esg port gig0/0/0 does correctly obtain a DHCP IP address, but it will not ping anywhere outside the local network.  In this case the computer can ping 172.20.40.1, the gig0/1 interface or any other IP on that network, but not anything outside.  Interesting enough, if I do an extended ping from 172.20.40.1 I CAN ping outside locations from the inside nat interface of the router.
Do I have to do routing table profiles or something?  I am very appreciatve of any help and will gladly give you login to my router....
---------------------------------------1941W----------------------- TESTING CONFIG
Router#sh run
Building configuration...
Current configuration : 2595 bytes
! Last configuration change at 00:52:02 UTC Mon Feb 27 2012
! NVRAM config last updated at 00:52:18 UTC Mon Feb 27 2012
version 15.2
hostname Router
boot-start-marker
boot-end-marker
logging buffered 9999999
no logging console
enable secret 5 password gone for security
enable password password gone for security
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.20.40.1 172.20.40.100
ip dhcp pool pool1
network 172.20.40.0 255.255.255.0
default-router 172.20.40.1
option 150 ip 76.204.73.242
dns-server 68.94.157.1
ip cef
license udi pid CISCO1941W-A/K9 sn FTX15240336
hw-module ism 0
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/ex0$
ip address 173.8.181.225 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
ip address 172.20.40.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
no ip address
interface GigabitEthernet0/0/0
no ip address
interface GigabitEthernet0/0/1
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
no ip address
interface Vlan1
ip address pool pool1
ip default-gateway 173.8.181.230
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 173.8.181.230
access-list 1 permit 172.20.40.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
line vty 0 4
login
transport input all
transport output all
scheduler allocate 20000 1000
end
Router#66.150.155.194
Everyone's tags (4)
1 REPLY
Purple
This means routing and NAT are working.
Can you provide output of host routing table and IP configuration and also the result of a traceroute to 8.8.8.8 from the host.
Regards.
Alain
674
