1941w router fail-over works but fail-back doesn't???
I haven't seen a setup like this before, and it just stopped working a couple months ago from the person before who set it up. I have changed the config to not show the hostname, external ip's, certificate, usernames, password hashes, and serial number. If anyone knows why this configuration would work when failing-over to the serial connection when the cable modem fails, but doesn't fail-back to the cable modem when the route becomes available again, I would appreciate any input. I tried many things, even updating to the most recent IOS, and this was working before. Thanks.
show run and show version output:
ROUTER#sh run
Building configuration...
Current configuration : 6747 bytes
! No configuration change since last restart
version 15.2
hostname ROUTER
boot-start-marker
boot system flash c1900-universalk9-mz.SPA.152-1.T.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
clock timezone Arizona -7 0
no ipv6 cef
ip dhcp excluded-address 10.0.1.1 10.0.1.30
ip dhcp excluded-address 10.0.1.101 10.0.1.254
ip dhcp pool MainIP
import all
network 10.0.1.0 255.255.255.0
domain-name inlandmarketing
dns-server 8.8.8.8
default-router 10.0.1.1
lease 5
ip domain name yourdomain.com
ip name-server 10.0.1.202
ip name-server 8.8.8.8
ip cef
crypto pki trustpoint TP-self-signed-1898501780
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1898501780
revocation-check none
rsakeypair TP-self-signed-1898501780
crypto pki certificate chain TP-self-signed-1898501780
certificate self-signed 01
   {cert here}
      quit
license udi pid CISCO1941/K9 sn {serialhere}
username {userhere} privilege 15 secret 5 {passwordhere}
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ETH-LAN$
ip address 10.0.1.1 255.255.255.0
ip flow ingress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Cable-Modem0/0/0
ip address {staticIPhere w/subnet}
ip flow ingress
ip nat outside
interface Serial0/1/0
ip flow ingress
ip nat outside
encapsulation ppp
service-module t1 fdl ansi
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map cable-modem interface Cable-Modem0/0/0 overload
ip nat inside source route-map t1 interface Serial0/1/0 overload
ip nat inside source static tcp 10.0.1.200 1723 {staticIPcablemodemhere} 1723 extendable
ip nat inside source static tcp 10.0.1.200 1723 {staticIPserialhere} 1723 extendable
ip route 0.0.0.0 0.0.0.0 Cable-Modem0/0/0
ip route 0.0.0.0 0.0.0.0 Serial0/1/0 50
ip access-list extended udp_rtp
permit udp host 10.0.1.27 any range 10000 20000
ip access-list extended udp_trp
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 2 permit 10.0.1.0 0.0.0.255
access-list 23 permit 10.0.1.0 0.0.0.255
route-map cable-modem permit 10
match ip address 1
match interface Cable-Modem0/0/0
route-map t1 permit 10
match ip address 2
match interface Serial0/1/0
route-map sip_nat permit 10
match ip address udp_rtp
snmp-server community ROUTER RW
snmp-server location ServerRoom
snmp-server enable traps entity-sensor threshold
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
ROUTER#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(1)T, RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 16:40 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
ROUTER uptime is 3 weeks, 2 days, 4 hours, 55 minutes
System restarted at 08:38:25 Arizona Wed Oct 12 2011
System image file is "flash:c1900-universalk9-mz.SPA.152-1.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com
Cisco CISCO1941/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID {serialhere}
2 Gigabit Ethernet interfaces
1 Serial interface
1 terminal line
1 Cable Modem interface
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#      PID            SN
*0        CISCO1941/K9          {serialhere}
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
data          None          None           None
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Frank
I am glad that when there was a problem today that it failed over and then failed back as desired. That is good
In your post this morning you say:"One thing I noticed, and changed, is setting the administrative  distance on the serial line to be greater on the default route than the  cable modem". Are you saying that before the 2 static default routes had the same administrative distance? In that case it should have done load balancing on both connections and not failover. So I am puzzled about what was going on.
And I am a bit puzzled about your question about the example from the docwiki. It shows using a route map to control NAT (actually PAT) to match to which interface the traffic is using. And the config in your original post shows that you are already doing this. And I would say that this article is actually showing a bad example of doing failover and I hope that you do not try to do it quite the same way. The problem with the failover shown in the article from docwiki is that it is using static default routes which specify a next hop address. But the interfaces where these addresses are located are Ethernet interfaces. There are lots of situations where you may lose connectivity to the next hop router over Ethernet but the Ethernet interface remains line protocol up. And when it is line protocol up then the static default route would not be removed from the routing table.
When doing failover in situations where the outbound routes are over Ethernet interfaces you frequently need to use something like Enhanced Object Tracking or IP SLA to track reachability of the next hop router and control the static route. I am not clear what the behavior of your able modem interface is and whether something like IP SLA might be beneficial for you.
Rick
Frank
I will start with a disclaimer - since we know that you have altered/omitted parts of the config but do not know what or how you changed it, there is a possibility that something you changed or omitted could be involved in the problem. But based on what is in the post here are my comments and suggestions.
- the config looks pretty straightforward and uses a static default route and a floating static default route to accomplish the failover.
- the failover depends on the static default route through the cable modem being withdrawn from the IP routing table. This usually would depend on the interface going line protocol down.
- the recovery should be that the static default route is put back into the routing table which should happen when the cable modem interface returns to line protocol up.
Can you capture and post the output of show interface and of show ip route while the problem is going on (and the router has failed over to the serial) and then capture and post the output of show interface and of show ip route when the cable modem problem is over but the router has not returned to the original static default route?
Rick
Rick,
I realize that what I omitted could very well be the source of the issue, so I made sure everything lined up as it should before I removed them. I have also been mulling over this for about a month now looking for issues in the config. Typically when the failover is tested the interface line is physically pulled from the back of the router, connectivity tests are ran, and it is plugged back in with a visit to whatsmyip.org following to verify that the device is back on the route of the cable modem instead of the t1/serial line. I am going to recreate the issue and post your requested output here by tomorrow morning.
I thought the same thing you did, but didn't check the tables while the issue was occuring. One thing I noticed, and changed, is setting the administrative distance on the serial line to be greater on the default route than the cable modem. Which in my mind means when the interface is up it will use that route as preferred over the serial connection with a distance of 50.
Frank
Rick,
The internet went down today, and it seems to have done exactly what you stated. It took the cable modem interface being unplugged to failover, and when it was plugged back in the default route back to cable modem took prevelance and failed back over correctly.
Do you know the following configuration example would work by using internet availability for a default route over port state?
http://docwiki.cisco.com/wiki/NAT_failover_with_DUAL_ISP_on_a_router_Configuration_Example
I appreciate your input.
Frank
Frank
Rick
While working on this today I received the following:
Nov  6 17:51:39.797: %LINK-3-UPDOWN: Interface Cable-Modem0/0/0, changed state to down
Nov  6 17:51:40.797: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cable-Modem0/0/0, changed state to down
Nov  6 17:51:43.621: %LINK-3-UPDOWN: Interface Cable-Modem0/0/0, changed state to up
Nov  6 17:53:55.945: %CABLE_MODEM_HWIC-3-FAILURE_DETECT: The Cable Modem Daughtercard has failed on interface Cable-Modem0/0/0.
IASROUTER#
Nov  6 17:54:23.645: %CABLE_MODEM_HWIC-3-CONTROL_PLANE_FAIL: RBCP failure : Adding service flow ACE failed - Ethernet type not supported
Nov  6 17:54:26.857: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cable-Modem0/0/0, changed state to up
During this time I verfied through whatsmyip.com that the route had actually failed over and was working. We're using the ipbase feature set and don't have the data or security packages enabled, or purchased, to use IP SLA or Enhanced Object Tracking, so we're going to purchase it for both routers and set it up so we can track reachability and also monitor for link status and send emails out when the backup route goes down while the primary is still active and working.
Thanks for your help Rick.
Frank
1391
