1p3q8t and 1p7q8t default QoS configs IOS and CATOS
Hi there,
Guys, I dont have the hardware to hard, but does anyone have the default config for these two port queueing types?
Also, in CatOS, you can do a wr term all and get the defaults, can you do this in IOS?
Many thx
Ken
Re: 1p3q8t and 1p7q8t default QoS configs IOS and CATOS
The defaults are all in the config guide, here:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a00801679f8.html
In IOS you can't get the defaults with a show command, unfortunately you need to look them up..
Andrew.
thats a bit of a pain :(
just wondering if anyone had a catOS switch and could do a write term all to get the defaults, but if no joy, I will work though the doc and work them out.
I am just comparing what Cisco best practises are ie,
set qos txq-ratio 1p7q8t 5 25 10 10 10 5 5 30
set qos wrr 1p7q8t 5 25 20 20 20 5 5
set qos wred 1p7q8t tx queue 1 80:100 100:100 100:100 100:100 100:100 100:100 100:100 100:100
set qos wred 1p7q8t tx queue 2 80:100 100:100 100:100 100:100 100:100 100:100 100:100 100:100
set qos wred 1p7q8t tx queue 3 80:100 100:100 100:100 100:100 100:100 100:100 100:100 100:100
set qos wred 1p7q8t tx queue 4 80:100 100:100 100:100 100:100 100:100 100:100 100:100 100:100
set qos wred 1p7q8t tx queue 5 80:100 100:100 100:100 100:100 100:100 100:100 100:100 100:100
set qos wred 1p7q8t tx queue 6 80:100 100:100 100:100 100:100 100:100 100:100 100:100 100:100
set qos wred 1p7q8t tx queue 7 80:100 100:100 100:100 100:100 100:100 100:100 100:100 100:100
set qos map 1p7q8t tx 1 1 cos 1
set qos map 1p7q8t tx 2 1 cos 0
set qos map 1p7q8t tx 3 1 cos 4
set qos map 1p7q8t tx 4 1 cos 2
set qos map 1p7q8t tx 5 1 cos 3
set qos map 1p7q8t tx 6 1 cos 6
set qos map 1p7q8t tx 7 1 cos 7
set qos map 1p7q8t tx 8 cos 5
and what the actual defaults are
Many thx indeed fella,
Ken
691
