06-10-2008 11:50 AM - edited 03-05-2019 11:32 PM
I have 2 3825 routers connected by a 30meg fiber link. I am having intermittent congestion problems and need some suggestions.
06-10-2008 11:54 AM
You could increase the bandwidth between the two routers or implement QoS. With QoS, you must remember that when you give bandwidth resource to one application, you're taking it away from another.
I hope that helps.
06-10-2008 04:18 PM
If not already doing so, try GTS at 30 Mbps.
E.g. (NB: syntax may be incorrect)
FastEthernet #
shaper 30000 (I think it's Kbps)
Or try hiearchal CBWFQ.
policy-map CBWFQ
class class-default
shaper 30000
FastEthernet #
service-policy output CBWFQ
06-11-2008 01:22 PM
Thank you both
