2 Cisco Stacks, need to add switches
I have 6 x 3750 switch split into 2 stacks ( A & B).  This is for our VMware hosts and SANs and it works well.  We have now run out of space and I have been given 2 x ws-3750G-12s-s chassis switches to add, 1 to each stack.   So I have a few question on added these to the stacks, here is a diag to help:
  1. These switches are slightly different to what we are using (in red) and we have to buy the SFP modules as the ports are empty, however will these switch be compatible?
  2. I will need to use the same old IOS 12.2(53)?
  3. I have highlighted in red where I think the stack cables need to go/moved does it look about right?
  4. Will pullin gthese stack cables cause downtime?
  5. I have to provision the stack to see the 4th switches is there any reboot required?
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
#1 yes (they are compatible)
#2 no, but stacks need to run same StackWise version - easiest to guarantee when all running same IOS version
#3 yes
#4 no (as long a connectivity is maintained between existing switches)
#5 no for existing switches, switch be added to stack should be connected with power off
PS:
BTW, the 12S model supports SDM templates unique to it, so insure it's running one of the "normal" SDM templates before adding to stack.
Hi Joseph,I didn't know I had
Hi Joseph,
I didn't know I had a reply!
How do I know whcih StackWise versions I'm using and the DSM templates?
Super Bronze
Disclaimer
Posting
Examples:
sh platform stack manager all
                 Stack State Machine View
Switch   Master/   Mac Address          Version    Current
Number   Member                          (maj.min)  State
1        Master    ####.####.####          1.45        Ready
2        Member    ####.####.####          1.45        Ready
3        Member    ####.####.####          1.45        Ready
sh sdm prefer
 The current template is "desktop routing" template.
 The selected template optimizes the resources in
 the switch to support this level of features for
 8 routed interfaces and 1024 VLANs.
  number of unicast mac addresses:                  3K
  number of IPv4 IGMP groups + multicast routes:    1K
  number of IPv4 unicast routes:                    11K
    number of directly-connected IPv4 hosts:        3K
    number of indirect IPv4 routes:                 8K
  number of IPv4 policy based routing aces:         0.5K
  number of IPv4/MAC qos aces:                      0.5K
  number of IPv4/MAC security aces:                 1K
Hi,What do you make of this:
Current stacks both on:
Stack A
“sh platform stack manager all”
1        Master    0023.ab09.d600          1.43        Ready
2        Member    f4ac.c1c8.f900          1.43        Ready
3        Member    18ef.6333.4f00          1.43        Ready
“sh switch”
Switch/Stack Mac Address : 0023.ab09.d600
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 0023.ab09.d600     5      0       Ready
 2       Member f4ac.c1c8.f900     1      0       Ready
 3       Member 18ef.6333.4f00     1      0       Ready
“sh sdm prefer”
 The current template is "desktop default" template.
2 Additional switches:
1        Master    0019.e7d1.fa80          1.45        Ready
sh sdm pref
 The current template is "aggregate default" template.
Super Bronze
Disclaimer
Posting
What do I make of your posted information?
I assume the -12S has a newer IOS since the stack version is newer.  It also appears to be running the the default "special" -12S SDM template.
The former might or might not be a problem, but to be safe, best to install the same IOS version on all stack members.  (55SE9 is very solid.)
The latter is a problem but should be fixable by changing the SDM template on the -12S (done using the SDM prefer command in config mode - do before trying to add to stack).
78
