2 different default routes for 2 different networks
I have a 3560 doing ip routing using eigrp.  I have 2 separate vlans, 1 is 10.15.16.0/24, and the other is 172.16.166.0/24.  I have 2 separate Firewalls that I want to have dedicated for each vlan.  How can I set a default route for the 10 subnet to 1 firewall, and a different default route for the 172 subnet for the other firewall?
thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: 2 different default routes for 2 different networks
thanks.
You will need to use PBR and you will need IPServices on your 3560. Config would look like -
access-list 101 permit ip 10.15.16.0 0.0.0.255 any
access-list 102 permit ip 172.16.166.0 0.0.0.255 any
route-map PBR permit 10
match ip address 101
set ip next-hop x.x.x.x <-- where x.x.x.x is the firewall for this vlan
route-map PBR permit 20
match ip address 102
set ip next-hop y.y.y.y  >-- where y.y.y.y is the firewall for this vlan
then apply the route-map to each vlan interface eg.
int vlan 10
ip address 10.15.16.1 255.255.255.0
ip policy route-map PBR
int vlan 11
ip address 172.16.166.1 255.255.255.0
Alternatively you could use vrf-lite (i think IPServices is needed for this as well) which allows each vlan to have it's own dedicated routing table on the 3560 but if you want the 2 vlans to be able to talk to each other PBR would be better. If you want these 2 vlans not to talk to ech other then vrf-lite is the way to go.
Jon
thanks.
int vlan 10
int vlan 11
Jon
Thanks Jon.
452
