2 Internet connections on ASA5510
I'm stock and I am sure it is simple but I can't find it.
I have an ASA5510 from which I am using 3 interfaces.
-One interface have the main internet connection router
-One interface is attache to a switch 3750 and has multiple virtual interface configured on it
-One interface has another internet connection router.
What I am trying to do is to have only one of the Vlan using the second internet connection and not the first one.
My idea was to just have a static route who says that on interface VLAN_B (for the special VLAN), all traffic goes to 2nd internet router interface.
But it does not route.
All I have is a default route configured : on interface Internet1 0.0.0.0/0 goes to 1st internet router interface.
Any idea or help ?
Thank you very much
1 ACCEPTED SOLUTION
what i can think of is to run the asa in multiple context mode.
use one context for routing the special vlan and use the other context for routing the rest.
I dont run the asa itsself in multiple context, but i have 2 fwsm' s running in multiple context and by multiple context what you want to do is possible.
You might want to check your reseller if a license is needed though for your asa or if its onboard already.
Good luck.
Silver
use route map
Posted by WebUser Nabil Benyoussef
Thanks for your answer but I don't see how route map would work here. I am not really familliar wth route map I have to say.
Re: 2 Internet connections on ASA5510
What he means is something like this:
Example: vlan 10 has to go out to router 2 and vlan 20 has to go out to router 1
For instance:
vlan 10 = 10.1.1.0 /24
vlan 20 = 10.1.2.0/24
Create ACL to match address ranges
access-list 101 permit ip 10.1.1.0 0.0.0.255 any
access-list 102 permit ip 10.1.2.0 0.0.0.255 any
Create route-map, match address 101 and set next-hop to router 2
route-map outbound permit 10
match ip address 101
set ip next-hop
Create route-map, match address 102 and set next-hop to router 1
route-map outbound permit 20
match ip address 102
set ip next-hop
Apply route-map
interface Ethernet0/x
ip policy route-map outbound
interface Ethernet0/y
Now when a packet enters ethernet0/x and its source ip = 10.1.1.x, a next hop to router 2 will be set. etc.
Thanks a lot for your answer, it makes it more clear. But one problem is still there, I am configuring that on my ASA 5510, and there is no "set ip next-hop" only set ip metric/metric-type
Do you think that by configuring OSPF I would be able to isolate the 2 connections ?
I mean if I put vlan 10 and router 1 in one OSPF process and Vlan 20 and router 2 in another OSPF process, would it allow me to apply kind of 2 different default gatway (one per process) ?
not sure, but i dont think so.
i m now logged in a asa here and will check some stuff.
ps. I did see that its indeed not possible to configure the next hop.
Good luck.
Thanks a lot for the search. I look into the multiple context mode.
Thanks A LOT Ton V Engelen.
I had already the good license for the multiple context and now it is working like a charm
very cool!
And you worked this config change out very fast!!!
Thanks!!
1117
