2 Lan and routing
Hi guys,
I would like interconnect 2 lan. One with 172.17.86.X submask 255.255.0.0 and another with 192.168.1.X submask 255.255.255.0
So i must have a router. I found RV180. It has an wan port, but could i set it in lan port ?
Doest it a good choice or there's a better way than this rv180 ? (only router ?)
Thanks for help !
Purple
2 Lan and routing
http://www.cisco.com/en/US/docs/routers/csbr/rv180w/administration/guide/rv180w_admin.pdf
pg 34 configuring vlan membership
Alain
2 Lan and routing
Thanks for this, but that's not what i mean.
I would like to config my lan 1 on wan port, and lan 2 to another port from switch.
If you want, i don't want to use rv180 as wan router but as lan router only.
My problem is : I would like few PCs on le lan1 can print (on lan printer) on the lan2, and if i don't mistake, i must use router to do this. 2 lan are currently physically separe
So rv180 can be helpful for my problem or a better solution to do this ?
Thanks a lot
2 Lan and routing
Bump please
Re: 2 Lan and routing
It's depending on what kind of switches you use. If you a switch to supports VLANs you need to configure the port that is attached to the RV180 as a trunk port. On the RV180 you use only one physical interface with multiple sub interfaces (page 36) to allow interVLAN communication.
221
