2 questions about Cisco 3750 Intervlan configuration
assalihin
I have about 20 switches scattered around 3 plants connected in a circle kind of.
--One 3750
--Six  Ce500-12 Ports (No Cli-Just web access)
--Twelve Ce500-24 Ports(No Cli-Just web access)
--One Dell Powerconnect 5324.
--Windows 2008 r2 acting as Dhcp server.
I am running out of Ips on my one and only subnet.
I would like to set up Vlans to separate traffic and also solve my ip issue.
Ip routing is enabled on the 3750. Looks like trunk encapsulation is too. This is from my Sh run:
interface GigabitEthernet1/0/23
switchport mode trunk
macro description cisco-switch
auto qos voip trust
spanning-tree link-type point-to-point
interface GigabitEthernet1/0/24
description Dell Switch
auto qos voip trust
interface GigabitEthernet1/0/25
auto qos voip trust
interface GigabitEthernet1/0/26
auto qos voip trust
interface GigabitEthernet1/0/27
description Fiber
auto qos voip trust
interface GigabitEthernet1/0/28
auto qos voip trust
interface Vlan1
ip address X.X.X.X X.X.X.X
ip default-gateway X.X.X.X
ip classless
ip http server
interface GigabitEthernet1/0/24 is copper connected to the 5324 PowerConnect Dell switch.
interface GigabitEthernet1/0/27 is Fiber connected to another Cisco ce500 Series switch
I am thinking about having 2 Vlans to start with. 10.5.0.0/24 and 10.6.0.0/24
My question is:
Which port should I use to configure the Sub interfaces for vlans?
What would be the commands to type in?
Thanks for your help
27 Replies 27
I think we are close to get this figured out.
1) I made sure all the switches have vlan 10 on them. I went to each and created it.
2) "The trunk links are allowing vlan 10". Since the are ce 500 I have no clue on how to do this.
3) The workstation doesn't get an ip from the dhcp yet
4) When I put a static ip on it I am able to ping my gateway (192.168.5.1)but nothing beyond that.
Thanks for taking the time to help,
Said
Said
Just to clarify -
1) from the workstation can you ping the vlan 11 interface on the 3750 switch ?
2) the ip helper-address under the vlan 10 interface - this is your DHCP server yes ?
3) have you created the scope on the DHCP server ?
Jon
1- yes from the workstation I can ping the vlan 10 and vlan1 interfaces on the 3750.
2- the dhcp server in the ip helper-address is my Dhcp server which is on vlan1
3- yes I created the scopes for vlan 10 and 11 on the Dhcp server
Sorry to keep having to clarify. You said before you couldn't ping anything except the vlan 10 interface but poitn 1 above suggests you can ping the vlan 1 interface on the 3750 which suggests the 3750 is routing correctly - can you confirm ?
Can you ping the DHCP server from the client in vlan 10.
What is the default-gateway on the DHCP server because before the 3750 was a L2 switch only so the vlan 1 interface on the 3750 could not have been the default-gateway of the DHCP server.
So i'm guessing the reply from the DHCP server is going to a different device than the 3750.
Can you confirm default-gateway of DHCP server and if it is not the 3750 then what device is it ?
Jon
assalihin
Actually I am the one has to apologize for taking all your time to help me out.
1- Yes I found out after I posted that I could ping the 3750 Vlan10 interface and also the 3750 vlan1 interface just fine from the workstation.
2- No I cannot ping Dhcp server from the client on Vlan 10.
3- The default-gateway on the dhcp server is the firewall. The same as what we put in the 3750.
Thanks for your time
No need to apologize.
3) is your problem.
It looks like vlan 1 is routed off the firewall. So you can do either -
i) add a route to your firewall for the vlan subnet pointing to the vlan 1 IP address on the 3750. This may or may not work. Your firewall needs to be able to route traffic back out of the interface on which it was received and somwe firewalls won't do that. If you have a pix/ASA you may be able to do it depending on the exact version of code it is running. Just adding a route for vlan 10 won't necessarily work.
or
ii) change the default-gateway on your DHCP server to be the vlan 1 IP address on the 3750. You may or may not want to do this. Be careful to understand what might happen if you do. It's difficult for me to say without fully understanding your setup. Ideally you would want vlan 1 routed off the 3750 as well as your other vlans but this could be a big change as you need to change the default-gateway for all vlan 1 clients. If most are DHCP then you can modify the scope but there will be servers etc. such as the DHCP server which will need to be manually changed.
Without either of the above the DHCP reply goes to the firewall instead of the 3750 and the firewall just drops it because it doesn't know about vlan 10.
Jon
I think I will opt for option#1. Can you give me an example to clarify:
"add a route to your firewall for the vlan subnet pointing to the vlan 1 IP address on the 3750. "
Like i said, it's not as simple as adding a route, at least not with Cisco models. What is make/model is your firewall ? If it is not Cisco you could try adding -
ip route 192.168.5.0 255.255.255.0
note the above syntax is for a Cisco router so it will be probably be different for the firewall.
If the firewall is a Cisco, then can you post make/model and what version of code it is running. To find out version of code just run "sh version" on the firewall.
Jon
I have Soniwall. I told them to leave the pix 515e alone but they
didn't listen:)
I will try to get Sonicwall support involved. maybe they can help with this one.
didn't listen:)
I don't know whether Sonicwall will support it or not but you can try. Don't know how to add a route to a Sonicwall but i believe they use a GUI to configure so it shouldn't be that hard or at least i hope not
Bear in mind, even with a route added it may still not work ie. it may need extra configuration or routing back out the same interface may just not be supported. Bit of trial and error i'm afraid.
Jon
but they didn't listen:)
They never do
Thanks again. I will keep you informed.
