12-03-2013 11:52 AM - edited 03-07-2019 04:54 PM
Hello Every body
i have the Following Items
2 ASA5510-SEC-BUN-K9
2 WS-C2960-24TC-L
6 HP DL380
6 Vlan as
10.78.0.46/24 outside
172.16.2.0/24 APP-DMZ
172.16.3.0/24 WEB-DMZ
172.16.4.0/24 AD
172.16.1.0/24 SYS-INFO
192.168.201.0/24 Database
6 Server connected to the Switches using 2 NIC each one connect to Switch A,B , the 2 Firewal must be Active Standby HA
the Desirable present Active Active Switches both NIC on each Server Should be Active mode no standby
what is the Configuration and the Best scenario the have Active active on Servers NICs and Swtiches
Kindly Check the Attached PIC for Explaination on Connection between the Each Gear..
Solved! Go to Solution.
12-03-2013 03:32 PM
Your ASA interfaces on the active and standby unit have to "see" each other (ASA-1 Fa0/0 needs to talk to ASA-2 Fa0/0 and so on). For that you need an additional link between the two switches. But the teaming can't work in active-active as for that you need at least the 2960-S which supports stacking. But you can use an active-passive mode with these switches.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
12-03-2013 03:32 PM
12-03-2013 09:36 PM
hello thank you for your effort
that is what excatlly i face with NIC teaming , can you sepcify the mian reasone for that in details i have to shutdwon on of theswitches so the servers can work is it about looping or what the reason for that i try hard with that and it doesnt work
12-03-2013 11:49 PM
Yes one of the reason is to prevent the loop as one of the link on the switch will be blocked due to STP.
