2 VLANs, 3 Routes, How?
I have a setup as attached. I have asked the question before but my config (described below)has not worked.
1. The 1841 Router has all the intelligence (ie routing info)
2. The 2 VLANs must use its own ADSL Router. (I understand this ought to be configured as PBR)
3. Both VLANs must connect to network 192.168.10.0 for a common application. (I have tried some access list but no good)
Here is my attempted config:
access-list 1 permit 192.168.1.0 0.0.0.255 any
access-list 2 permit 192.168.2.0 0.0.0.255 any
access-list 100 deny ip any 192.168.10.0 0.0.0.255
route-map ADSL permit 10
match ip address 100
match ip address 1
set ip next-hop 192.168.1.2
route-map ADSL permit 20
match ip address 2
set ip next-hop 192.168.2.2
int fastethernet 0/0
ip policy route-map ADSL
ip route 192.168.10.0 0.0.0.255 10.0.0.1 (note the ip 10.0.0.1 is the wireless interface between the 2 1841)
Any suggestions?
Hall of Fame Super Silver
Re: 2 VLANs, 3 Routes, How?
your configuration of PBR has to be changed.
As far as I know, the problem are the ACLs.
First skip ACL 100.
use the following ACLs:
access-list 101 deny 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 permit 192.168.1.0 0.0.0.255 any
access-list 102 deny 192.168.2.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 102 permit 192.168.2.0 0.0.0.255 any
the route-map becomes
match ip address 101
match ip address 102
This should work.
However, the best solution would be to configure a static route for 192.168.10.0/24 on the two ADSL routers and make them the default gateways for VLAN1 and VLan2. So PCs will be redirected via icmp redirect to the 1841 when accessing net 192.168.10.0/24 and will use the ADSL router for everything else.
Hope to help
Giuseppe
I understand your point. However the application is actually VoIP and its best to limit the number of routers dealing with this class traffic.
I have all the QoS configured on the 1841 and the ADSL routers are non-QoS enabled devices.
thx
183
