11-16-2010 11:36 AM - edited 03-06-2019 02:05 PM
Is it possible to have 1 public VLAN and 1 private NAT'd VLAN on the same port on a 3925?
11-16-2010 12:36 PM
Zach
Not sure what you mean.
If the port is a L2 port then make it a trunk link.
If the port is L3 simply use secondary addressing.
Jon
11-16-2010 01:27 PM
Maybe explaining what I would like to do will make it easier to understand what I am trying to accomplish : )
Currently have group of customer under a NAT (VLAN1) network on one LAN port of my router - private IP block (192.168.0.0/24) NATing to public IP (x.x.x.x).
One customer in that NAT needs to put a public IP in their router. Under current NAT network, they are unable to do this.
Can I keep the NAT settings (VLAN1) on this port and also assign a second VLAN (VLAN2) to this port with a public IP (y.y.y.y) so existing customers remain the same while the other customer is able to enter a public IP in their router (y.y.y.y)?
11-17-2010 05:51 AM
Zach
Sorry, still not getting it. Cna you perhaps post a config of the router specifyinh exactly what you are trying to do.
Jon
11-17-2010 07:18 AM
You can do the following to resolve your problem:
If you need more expalnation about how to configure this option send us how you have configured your router.
Attn.
Roger
