20gbit Port-channels using sfp+ ports
I am hoping to implement a cost affective solution that can utilise the uplinks ports on the 2960-X & XR series switch and the appropriate up/downlink modules for the 3750-X series switch
Would anyone know if it is possible to bundle the 10gbit sfp+ ports into a 20gbit port-channel?
Has anyone done this or could they point me in the right direction for documentation?
1 ACCEPTED SOLUTION
VIP Super Bronze
Yes, you can bundle multiple 10Gig ports on all these devices as long as you have the proper modules.  The 2960-X supports up to 24 Etherchannels and the XR supports up to 48.
If you are uplnking the 2960 series to 3750-X, you need a 10Gig module for the 3750-X series.
VIP Super Bronze
Assuming your 2960x series has SFP+ ports then you should be able to do that.
You would need a C3KX-NM-10G for the 3750x.
Super Bronze
Re: 20gbit Port-channels using sfp+ ports
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
BTW, don't forget, you only have two 10g ports per 3750X.
Thanks for clarifying that everyone
I am looking to aggregate x4 20gbit port-channels (8 links) into x4 3750-x with the appropriate modules
Thanks again
Hall of Fame Super Gold
Sure you can.  Whether or not your switch can fully push 20 Gbps is another question.
271
