2509 with Octal cable - Large number of Overruns?
Setting up a 2509 for oob console access, and am seeing large numbers of overruns:
OOB-01-SYD#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 0 0/0 -
I 1 TTY 9600/9600 - - - - - 0 0 0/0 -
2 TTY 9600/9600 - - - - - 0 0 0/0 -
3 TTY 9600/9600 - - - - - 1 0 0/0 -
* 4 TTY 9600/9600 - - - - - 1 78 702/2096 -
5 TTY 9600/9600 - - - - - 1 15 775/2333 -
6 TTY 9600/9600 - - - - - 0 0 0/0 -
7 TTY 9600/9600 - - - - - 0 0 0/0 -
8 TTY 9600/9600 - - - - - 5 3340 0/0 -
9 AUX 9600/9600 - inout - - - 2 0 0/0 -
* 10 VTY - - - - - 10 0 0/0 -
11 VTY - - - - - 0 0 0/0 -
12 VTY - - - - - 0 0 0/0 -
13 VTY - - - - - 0 0 0/0 -
14 VTY - - - - - 0 0 0/0 -
I've tried a different octal cable, but still seeing overruns.
Then on a 2960 switch connected via console to one of the octals, I see large number of overruns also:
#sh line
* 0 CTY - - - - - 0 2 0/30755582 -
What would be causing this, and is there anything I can do(Config-wise) to stop the overruns - As "sh run" on a connected switch stops after about 17 lines (If I reboot the 2509, it will allow correct console access to connected switches for approx a day before becomming unusable again)
Thanks in advance.
Hall of Fame Super Silver
Re: 2509 with Octal cable - Large number of Overruns?
Hello John,
post sh ver and configuration of lines.
There are some commands that may need to be added.
Hope to help
Giuseppe
Thanks Giuseppe - I believe I have found a solution.
Enabling software flow control on the connected switches line con 0 has stopped the overrun number increasing(Well for the last few hours anyway)
251
