Webcast-Catalyst9k
2514 Access Server Problem
Hi All,
I have set-up a home lab using a 2514 as an access server to 2, 2620's, 2 2, 2600's, and 2, 2950-C switches. I have configured my 'ip host' table, but I am still unable to access each device. I have an octal cable going from the asynchronous 1-8 port on the 2514 to each console port of previously mentioned devices.
Current configuration : 702 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname AS
ip subnet-zero
no ip domain-lookup
ip host R4 2006 10.10.1.1
ip host R3 2005 10.10.1.1
ip host R2 2004 10.10.1.1
ip host R1 2003 10.10.1.1
ip host SW2 2002 10.1.1.1
ip host SW1 2001 10.1.1.1
interface Loopback0
ip address 10.1.1.1 255.255.255.0
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip http server
ip classless
line con 0
exec-timeout 0 0
logging synchronous
line 1 8
no flush-at-activation
no exec
transport input all
line aux 0
line vty 0 4
login
end
AS#sw SW1
Translating "SW1"
Trying SW1 (10.1.1.1, 2001)...
% Connection refused by remote host
AS#
Any hints as to what I need to do to get this to work? I had tried adding in the command 'transport input none' but this command is unavailable under line console 0. I based this off of a tutorial I found on Chris Bryant's website.
http://www.thebryantadvantage.com/CCNACCNPHomeLabAccessServerTutorial.htm
Thank you,
Jonathan
Gold
Re: 2514 Access Server Problem
Could you try command
no exec
on all used lines
M.
hope that helps rate if it does
Instead of 'transport input none', could you try 'transport output none'. Like they told you, the command 'no exec' is also necessary.
See if it works.
Purple
Try adding the following . the rest looks ok. If it still doesn't work I would look at the cables and connctors you are using to connect from the octal to the console ports.
line 1 16
no exec
login authentication line
modem InOut
transport input telnet
autohangup
225
