01-11-2008 06:22 PM - edited 03-05-2019 08:25 PM
Ok...this will make you all laugh.....however I am way over on this one......
I have set-up the router with a simple configuration and then "copy startup-config running-config...
Reboot the router and it ALWAYS goes back to the System Configuration Dialog....
It is like it never sees the running-config...I have checked the startup-config and the running-config and I find nothing that would be causing this....
Also there is NO tftpserver running for the router to grab the files from the lan...
Please......what am i missing???
Solved! Go to Solution.
01-11-2008 07:39 PM
Your config register is incorrect , change it to 0X2102 and reboot .
01-11-2008 07:39 PM
01-11-2008 08:01 PM
Thanks.........I found Document ID: 6201- Why Does My Router Lose Its Configuration During Reboot?
But thanks for the reply...that was the problem....
