Webcast-Catalyst9k
2621 nvram
Has anyone ever come across this error message on a 2821 router during boot ?
% Error opening nvram:/ifIndex-table No such file or directory
I can't seem to find anything in cco that explains this error message.
Any advice appreciated.
Thanks.
Hall of Fame Super Gold
Re: 2621 nvram
Likely a cosmetic IOS bug that you can ignore if everything else works normally.
Bronze
Re: 2621 nvram
This pertains to the NVRAM file "ifindex-table", which is:
Interface Index Table
It is a file that contains a matrix with numerical values assigned to each interface on the device. It looks like it is mostly related to SNMP for tracking the names of interfaces for polling.
Here are a few links that might clear this up:
http://supportwiki.cisco.com/ViewWiki/index.php/What_is_interface_index_(ifindex)_persistence%3F
The Feature navigator describes it as:
Interface Index Persistence Maintain correspondence between ifIndex values and actual interfaces across reboots.
This will describe it in detail:
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t5/feature/guide/dt5ifidx.html
351
