2650 with 12.4T (non-XM)
sean.cline
Not sure if this is the correct place to ask but I have a lab at home to study for CCNA and beyond. I came accross a post on the interwebs that uploading 12.4T may be possible on a non-XM 2600 router.
I installed the version that would fit 12.4.9T I believe, it boots and functions fine. It has 128D/32F, do you forsee any issue of doing this for a lab work in the future or should I invest in the XM series to get to the 12.4T series.
Richard Burts
Sean
If it boots and functions fine then it should be good for you lab work.
Rick
Rick
