What I have been seeing is a site will loose power and then after the equipment is back up the E/N switch port will be blowing errors. The only way I have been able to clear this is by resetting the switch. Any suggestions.
When the power goes off is your Switch still on and working ?
Also not sure about E/N switch port as you have mentioned over here..
What about the other end of the switch port ?
Did you try monitoring the other end too ?
regds
