2811 and HWIC-4ESW
hello guys,
I am recently decided to ride the CCIE quest for Voice. I am currently in the process of making my lab. I have ordered all my equipment from a Cisco reseller and was checking my equipment that i have ordered are in working condition. However when i connect HWIC-4ESW to Cisco 2811 I dont see the the interfaces. I then checked sh diag and it give the following msg "WIC Slot 2:  Unknown WAN daughter card.WIC module not supported/disabled in this slot"
Could anyone of you tell me what I am doing wrong.... I am sure that this module is compatible with 2811 or may be not....
The router has no configuration (all default). IOS version is c2800nm-spservicesk9-mz.124-2.T.bin. Has a AIM-CUE and MFT-2E1 installed in it.....
Everyone's tags (5)
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: 2811 and HWIC-4ESW
No, as soon as the interface is installed, the router should recognize the module.  No need for additional commands.
Also, have you rebooted the router?
one more thing:
Is the module all the way in?  Make sure there is no bent pin on the module or the router.
VIP Super Bronze
2811 and HWIC-4ESW
The module is compatible with 2811.  Also, you have 12.4-T release software which supports this module.
Cisco 2800 Series
12.3(8)T (fourth release of Cisco IOS Software Release 12.3T): IP Base Image
also table-4 in this link shows the module being compatable with 2800 series.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016bf0b.html
Do you have another router that you can put this module in it and test it?
If above does not work, you may want to load a different IOS version with T release and test.
2811 and HWIC-4ESW
Hi Raza,
Yeah, I had tried both switching in into a different router (2811) and also tired with a different IOS image. It still give me the same error.... below is the output of show diag:
        WIC Slot 0:
        E1 (2 port) Multi-Flex Trunk WAN daughter card
        Hardware revision 1.0           Board revision A0
        Serial number     35997007      Part number    800-04479-05
        Version Identifier     V02      FRU Part Number     VWIC-2MFT-E1
        Test history      0x0           RMA number     00-00-00
        Connector type    PCI
        EEPROM format version 1
        EEPROM contents (hex):
          0x20: 01 23 01 00 02 25 45 4F 50 11 7F 05 00 00 00 00
          0x30: 50 00 00 00 07 10 18 00 FF FF FF FF FF FF FF FF
        WIC Slot 2:
        Hardware Revision        : 1.0
        Part Number              : 73-8958-01
        Board Revision           : C0
        Deviation Number         : 0-0
        Fab Version              : 01
        PCB Serial Number        : FOC08161RKF
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Top Assy. Part Number    : 800-24120-01
        Connector Type           : 01
        Base MAC Address         : 000f.f750.621c
        MAC Address block size   : 4
        Product (FRU) Number     : NM-1V=
        EEPROM format version 4
          0x00: 04 FF 40 00 64 41 01 00 82 49 22 FE 01 42 43 30
          0x10: 80 00 00 00 00 02 01 C1 8B 46 4F 43 30 38 31 36
          0x20: 31 52 4B 46 03 00 81 00 00 00 00 04 00 C0 46 03
          0x30: 20 00 5E 38 01 05 01 CF 06 00 0F F7 50 62 1C 43
          0x40: 00 04 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Is it possible that the module is dead? and is there any way to find out?
VIP Super Bronze
2811 and HWIC-4ESW
Syed,
Can you also try a different slot?
It could be that the module is bad.  If you have warranty on it, you can replace it.
2811 and HWIC-4ESW
Its the same.... I think its a bad module. Yeah i have 30 days warrenty, will get it replaced.... Thanks for the support....
I know the answer to my question will be no but just to confirm, do you think i have to enable anything like a service or type a command inorder to fire it up????
VIP Super Bronze
one more thing:
Yes tired relocating the same result.... I think the module is bad. Nope there r no bent pins on either one.
2811 and HWIC-4ESW
Try upgrading to 12.4(24)T7. The 2811 router requires at minimum 12.4(24)T5. Also note the HWIC can only go in a certain slot on the router. You might want to check that but I think those are slots 0,1,3 ; not slot 2 , or something like that.
2736
