2811 LAN to LAN IPSEC
emmaylots
Dear all,
I want to setup a LAN to LAN IPSEC secured connection using 2811 routers.
LAN 1: IP: 172.30.128.0/24
LAN 2: 172.30.129.0/24
ROUTERS VERSION:
faraday#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 18-Jul-07 06:21 by pt_rel_team
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2000 by cisco Systems, Inc.
System image file is "c2800nm-advipservicesk9-mz.124-15.T1.bin"
ROUTER1: FARADAY
LAN int fa0/1: 172.30.128.254/24
WAN int fa0/0: 192.168.128.254/24
Config:
faraday#sh running-config
Building configuration...
Current configuration : 1350 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname faraday
enable secret 5 $1$mERr$Rff1owNQdMUvylEoNMPHO1
username ayodeji privilege 0 secret 5 $1$mERr$kMTDoyBtdE/MEgmAcmJ4u/
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key zumabuja address 192.168.128.253
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map myvpn 10 ipsec-isakmp
set peer 192.168.128.253
set transform-set myset
match address 101-103
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/0
description "WAN link"
ip address 192.168.128.254 255.255.255.0
duplex full
speed 100
crypto map myvpn
interface FastEthernet0/1
description "LAN link"
ip address 172.30.128.254 255.255.255.0
duplex full
speed 100
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet1/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.128.253
ip access-list extended 101-103
permit ip 172.30.128.0 0.0.0.255 172.30.129.0 0.0.0.255
permit ip 172.30.129.0 0.0.0.255 172.30.128.0 0.0.0.255
line con 0
login local
line vty 0 4
login
end
ROUTER2: ROBOCOP
LAN int fa0/1: 172.30.129.254/24
WAN int fa0/0: 192.168.128.253/24
Config:
robocop#sh runn
robocop#sh running-config
Current configuration : 1362 bytes
version 12.4
hostname robocop
hash md5
crypto isakmp key zumaabuja address 192.168.128.254
set peer 192.168.128.254
no ip domain-lookup
description "WAN link to faraday"
ip address 192.168.128.253 255.255.255.0
duplex full
speed 100
crypto map myvpn
ip address 172.30.129.254 255.255.255.0
duplex full
speed 100
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.128.254
line con 0
login local
line vty 0 4
login
end
I have two laptops at both end, Laptop1: 172.30.129.100, while Laptop2: 172.30.128.100.
I can ping the WAN interfaces of both routers from any of the laptops, but the laptops are unable to ping each other.
I have turned on debugging and keep getting below error on FARADAY:
ISAKMP (0:0): vendor ID is NAT-T RFC 3947
ISAKMP:(0): processing vendor id payload
ISAKMP:(0): vendor ID seems Unity/DPD but major 245 mismatch
ISAKMP (0:0): vendor ID is NAT-T v7
ISAKMP:(0): vendor ID seems Unity/DPD but major 157 mismatch
ISAKMP:(0): vendor ID is NAT-T v3
ISAKMP:(0): vendor ID seems Unity/DPD but major 123 mismatch
ISAKMP:(0): vendor ID is NAT-T v2
ISAKMP:(0):found peer pre-shared key matching192.168.128.253
ISAKMP:(0): local preshared key found
ISAKMP : Scanning profiles for xauth ...
ISAKMP:(0):Checking ISAKMP transform 1 against priority 10 policy
ISAKMP:      encryption ENC-3DES
ISAKMP:      key length of 56
ISAKMP:      hash MD5
ISAKMP:      group 1
ISAKMP:      auth pre-share
ISAKMP:      life type in seconds
ISAKMP:      life duration (basic) of 86400
ISAKMP:(0):atts are acceptable. Next payload is 0
ISAKMP:(0):Acceptable atts:actual life: 0
ISAKMP:(0):Acceptable atts:life: 0
ISAKMP:(0):Basic life_in_seconds:86400
ISAKMP:(0):Returning Actual lifetime: 86400
ISAKMP:(0)::Started lifetime timer: 86400.
ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM1
ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
ISAKMP:(0): sending packet to 192.168.128.253 my_port 500 peer_port 500 (R) MM_SA_SETUP
ISAKMP:(0):Sending an IKE IPv4 Packet.
ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM2
ISAKMP (0:1073): received packet from 192.168.128.253 dport 500 sport 500 Global (R) MM_KEY_EXCH
ISAKMP: reserved not zero on ID payload!
%CRYPTO-4-IKMP_BAD_MESSAGE: IKE message from 192.168.128.253 failed its sanity check or is malformed
ISAKMP (0:1073): incrementing error counter on sa, attempt 1 of 5: reset_retransmission
ISAKMP:(1073): retransmitting phase 1 MM_KEY_EXCH...
ISAKMP (0:1073): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
ISAKMP:(1073): sending packet to 192.168.128.253 my_port 500 peer_port 500 (R) MM_KEY_EXCH
ISAKMP:(1073):Sending an IKE IPv4 Packet.
ISAKMP:(1073): phase 1 packet is a duplicate of a previous packet.
ISAKMP:(1073): retransmission skipped for phase 1 (time since last transmission 640)
ISAKMP (0:1073): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
ISAKMP:(1073): retransmission skipped for phase 1 (time since last transmission 0)
ISAKMP (0:1073): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
ISAKMP (0:1073): incrementing error counter on sa, attempt 5 of 5: retransmit phase 1
ISAKMP:(1073):peer does not do paranoid keepalives.
ISAKMP:(1073):deleting SA reason "Death by retransmission P1" state (R) MM_KEY_EXCH (peer 192.168.128.253)
ISAKMP: Unlocking peer struct 0x483E9800 for isadb_mark_sa_deleted(), count 0
ISAKMP: Deleting peer node by peer_reap for 192.168.128.253: 483E9800
ISAKMP:(1073):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
ISAKMP:(1073):Old State = IKE_R_MM4  New State = IKE_DEST_SA
IPSEC(key_engine): got a queue event with 1 KMI message(s)
ISAKMP (0:1073): received packet from 192.168.128.253 dport 500 sport 500 Global (R) MM_NO_STATE
ISAKMP:(1073):purging SA., sa=48CC3E60, delme=48CC3E60
When I do "sh crypto isakmp sa", I get:
faraday#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id slot status
192.168.128.253 192.168.128.254 MM_SA_SETUP       1073    0 ACTIVE (deleted)
IPv6 Crypto ISAKMP SA
Kindly assist!
Reza Sharifi
crypto isakmp keyzumaabuja address 192.168.128.254
Your key passwords are not the same.
Make them both the same and try again
Reza Sharifi
Dear Reza,
THANK YOU!
I've been on this for about six hours! Never noticed the difference in the isakmp keys!
You are so cool!
You are certainly welcome and thanks for the rating.
Sorry to bother you, is this security level okay, how can I make it more secure?
Yes, the security is fine.
Reza
Thanks..
