2811 Router loses connection to Motorola Cable Modem
Hi All,
Need a little Help !
I have a Cisco 2811 fa0/1 configured for DHCP connected to a Motorola Surfboard cable Modem (SB4100).
The FA0/1 is constantly dropping during the day, the longest period the connection stays up for is around 50 minutes.
I work from home during the Day and constantly access my companies intranet, using an SSLVPN. I also use Webex sessions during the day.
However the Irony is the connection is ok in the evening, when I have no need to access SSLVPN or Webex.
I thought i may have a faulty port, therefore I have already swapped ports but this makes no difference.
Also I'm constantly receiving the following error: %SCHED-3-STUCKMTMR: Sleep with expired managed timer 44F2CD70, time 0x11CE4BE8 (00:00:00 ago). -Process= "L2MM", ipl= 4, pid= 105 -Traceback= 0x4101CA0C 0x41E13C48 0x41E1407C 0x404C632C.
Your help is appreciated
Config file attached
Charles
1 ACCEPTED SOLUTION
Re: 2811 Router loses connection to Motorola Cable Modem
Does the link fa0/1 actually flap or do you lose connection through it?
-Matt
Hello Charles,
Does the router reboot or does the interface just go down?   I see you are running 12.4(13b) code so I did find a bug, CSCsc62064, for the traceback message along with reduced performance.  It is fixed in 12.4(15)T6, so I suspect a software upgrade might resolve this for you.
-Matt
Message was edited by: Matthew Blanshard
Thanks Matthew,
I shall give the IOS a try.
Charles
Hi Matthew,
I didn't answer your question ! The Router doesn't reboot, The CPU process is < 40% at it's peak, but is running around 10% constant.
The Cable modem appears to be operating.
Charles
-Matt
Matthew,
Thanks for your help.
I've upgraded the flash to c2800nm-ipvoicek9-mz.124-25c.bin. and the issue has been resolved.
Thanks again.
Outstanding! Glad to help out.
-Matt
667
