Community Member
2811 Router Question
I have a 2811 router and i wish to upgrade the IOS to the most recent.  Reaching the download page, i saw several options:
Can anyone please explain to me the difference?
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: 2811 Router Question
Thanks.
Mark
It's simply a version of the major releases ie. 12.4, 12.4T and 15 (3 versions).  If you want to see what differences there are you should use software advisor -
Software advisor
this allows you to compare 2 versions side by side so you can decide which one is the one you need. It's mainly to do with features needed.
Jon
Thanks.
Mark
Software advisor
Jon
Community Member
Hi Jon,
Thanks for the reply.
Just wish to clarify, does that mean that i can download any on the list without having to worry about hardware compatibility issues?
Thanks again.
Silver
Hello Mark,
About your last comment I would look at the memory requirments on the right panel :
For example for IOS 124-25c releases  => Minimum Memory:        DRAM:256        MB                                                               Flash:64        MB
for 150-1.XA3 IP BASE => Minimum Memory:        DRAM:256        MB                                                               Flash:64        MB
for 150-1.XA3        ADVANCED ENTERPRISE  SERVICES => Minimum Memory:        DRAM:512        MB                                                               Flash:128        MB
You can check your RAM and Flash memory capabilities via the 'show version' on your router (memory upgrade if necessary).
Also for some modules there is some minimum cisco IOS release for the module to be detected (ex for HWIC-1T etc ..). You can check for specific WIC data sheets for the details.
Karim
527
