Webcast-Catalyst9k
2811 with 4 fxo ports
I am unable to call 911 from a phone, I have checked the analog lines they work fine and can call 911. But when I dial from a phone I get the dial tone back.
Attached are the log files and config
Silver
Re: 2811 with 4 fxo ports
Configure voice rtp send-recv on the gateway-Sometimes you have one-way audio problems only when calling specific numbers, such as 411 or 911 in the North American numbering plan (NANP) or after you transfer a call or put it on hold. If you are having these problems when going through a Cisco IOS software voice gateway, be sure that the voice rtp send-recv command is configured on the gateway. Numbers such as 411 and 911 sometimes do not send back answer supervision when the remote end answers. As a result, the Cisco IOS software voice gateway does not cut through audio in both directions to prevent toll fraud. Configuring the voice rtp send-recv command forces the voice gateway to cut through audio in both directions immediately.
I have had the same issue and used the above command as a temp fix, but it is my understanding that this type of call will fail after 3 minutes (at least according to TAC). Good enough for most calls, but not really a permanent fix.
Has anyone come across a permanent fix? Right now we are not receiving the Connect message from Telco and are having a devil of a time getting anywhere with them.
Atiq,
You mean, when you plug this line to a analog phone the you can dial 911 and it works well. Right?
If so,Please test the following commands
dial-peer voice 9100 pots
destination-pattern 911
forward-digits all
port 0/0/0
dial-peer voice 9101 pots
forward-digits all
port 0/0/1
dial-peer voice 9102 pots
forward-digits all
port 0/0/2
dial-peer voice 9103 pots
forward-digits all
port 0/0/3
Note: Or you need to put any number before dialing 911. Please let me know.
HTH,
Toshi
193
