2821 and 3550 with DHCP
shimabuku
For some reason I am unable to get o fut to the internet with my laptop. From the 2821 I can ping out just fine. I enabled DHCP on the 3550 and am able to pull a proper ip address. I also can ping the default gateway and router from my laptop but not any further. Currently I am stumped and have no clue what to do from here. Any help would be greatly appreciated. Below are the running configs for the switch and router.
WS-C3550-48-EMI
Building configuration...
Current configuration : 4341 bytes
version 12.2
no service pad
service password-encryption
hostname SWITCH
username pepsi privilege 15 password 7 095F5B130C0E1E445E
no aaa new-model
ip subnet-zero
ip routing
ip dhcp excluded-address 10.0.2.1 10.0.2.99
ip dhcp pool VLAN100
   network 10.0.2.0 255.255.255.0
   default-router 10.0.2.1
   dns-server 8.8.8.8
vtp mode transparent
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 99
name VLAN99
vlan 100
name VLAN100
interface FastEthernet0/47
switchport access vlan 100
switchport mode access
spanning-tree portfast
interface FastEthernet0/48
no switchport
ip address 10.0.1.2 255.255.255.0
interface Vlan1
no ip address
shutdown
interface Vlan100
ip address 10.0.2.2 255.255.255.0
no ip redirects
standby 1 ip 10.0.2.1
standby 1 preempt
ip default-gateway 10.0.1.1
ip classless
ip http server
ip http secure-server
SWITCH#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 2 subnets
C       10.0.2.0 is directly connected, Vlan100
C       10.0.1.0 is directly connected, FastEthernet0/48
CISCO2821
Current configuration : 1471 bytes
! Last configuration change at 07:01:26 UTC Thu Aug 29 2013 by nohara
version 15.1
hostname ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2821 sn FTX1112A4EE
username pepsi privilege 15 password 7 105D1C03101C1B5D59
redundancy
interface GigabitEthernet0/0
description <==WAN==>
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
description <==LAN==>
ip address 10.0.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 10.0.2.0 255.255.255.0 GigabitEthernet0/1
logging esm config
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.0.2.0 0.0.0.255
Router#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, GigabitEthernet0/0
      10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C        10.0.1.0/24 is directly connected, GigabitEthernet0/1
L        10.0.1.1/32 is directly connected, GigabitEthernet0/1
S        10.0.2.0/24 is directly connected, GigabitEthernet0/1
S        10.100.0.1/32 [254/0] via 99.91.24.1, GigabitEthernet0/0
      99.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        99.91.24.0/21 is directly connected, GigabitEthernet0/0
L        99.91.29.77/32 is directly connected, GigabitEthernet0/0
2 Accepted Solutions
Peter Paluch
There are a few configuration issues in your network.
  • On the switch, remove the ip default-gateway command and replace it with ip route 0.0.0.0 0.0.0.0 10.0.1.1. As soon as you activate IP routing on your switch, the ip default-gateway command is ignored. You can also see in the show ip route output on the switch that there is no default gateway/default route present. The ip default-gateway command is used only when the IP routing is disabled on a device.
  • On the router, the routing is configured improperly. It is not recommended to define static routes that point out Ethernet (or any other multi-access) interfaces. This makes the router rely on ProxyARP functionality in the neighboring routers which may not be activated, and increases the ARP load and cache size. Therefore, on the router, remove both ip route 10.0.2.0 255.255.255.0 gi0/1 and ip route 0.0.0.0 0.0.0.0 gi0/0 commands, and replace them with:
    ip route 10.0.2.0 255.255.255.0 10.0.1.2
    ip route 0.0.0.0 0.0.0.0 dhcp
Try it out and let us know please.
Best regards,
Peter
I've spotted one more configuration error on your router - the NAT is configured incorrectly. Remove the line
and replace it with
ip nat inside source list 1 interface GigabitEthernet0/0 overload
You do not need to change the DHCP server settings - they have no impact on your current connectivity.
Best regards,
Peter
8 Replies 8
Peter Paluch
Best regards,
Peter
Still no dice, unable to ping out via fa0/47 on the switch. Would it make a difference if I moved DHCP service to the router instead and have the switch relay it via helper-address?
ROUTER#show ip route
Gateway of last resort is 99.91.24.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 99.91.24.1
S        10.0.2.0/24 [1/0] via 10.0.1.2
Gateway of last resort is 10.0.1.1 to network 0.0.0.0
S*   0.0.0.0/0 [1/0] via 10.0.1.1
and replace it with
Best regards,
Peter
Spot on Peter! Appreciate the help! Just for the practice, I adjusted the switch to be the DHCP relay and the router as the DHCP server. This also worked by removing the ip dhcp statements and removing the standby statements from VLAN 100. I just added the helper-address to VLAN 100 and put the ip dhcp statements on the router. Which is the preferred method? Switch as the dhcp relay or switch as dhcp server?
It is good to know things are working! Thank you
I do not have any definitive answer. In my opinion, this depends strongly on the topology of your network - how many LANs with DHCP clients you have and where are they located. The usage of DHCP Relay basically leads towards the concept of a centralized DHCP - have a single DHCP server for multiple (V)LANs at some central location where it is accessible from all (V)LANs. If you have only a single VLAN, or only a handful of VLANs that are all terminated on a single L3 distribution switch then it is easiest to create the DHCP server on that switch. If you have a number of VLANs spread over more L3 distribution switches, it is easier to maintain a central DHCP server and use the DHCP Relay feature.
Would this answer your question? Please feel welcome to ask further!
Best regards,
Peter
first create your network digram and understand it , then you  can take any decision as per your network diagram,
regarding your network , DHCP relay basically leads towards the concept of a centralized DHCO.
Single DHCP server for multiple vlans at some central locatio.
Rate the helpfull post
Hello Aman,
Thank you for joining the discussion.
I have noticed you have recently joined multiple discussions on Cisco Support Community. Each time, you have simply quoted parts of other poster's responses and asked for rating. I am, honestly speaking, confused about the reason you are doing this. I apologize if this remark is offending but the way you are behaving gives an impression that you are basically stealing other people's ideas and ask to be rated for them - and that would be most rude and inappropriate. I am not accusing you of doing that - I am only telling you how your postings look like.
If you want to direct others to the answers you personally consider correct and ask people to rate those posters who gave correct answers, then by all means - they all deserve their ratings. However, it is sufficient to simply write whose answer you consider to be correct, and it is neither required nor useful to quote what others have written. Taking out parts of other poster's answers and presenting them as your own along with asking for rating, however, would be the height of impudence.
Once again, I apologize if I misunderstood your intentions, and I do not want to offend you in any way, nor discourage you from posting on CSC. You are always welcome to join and discuss things from your own view, standpoint, experiences and ideas.
Best regards,
Peter
