04-08-2009 03:07 AM - edited 03-06-2019 05:04 AM
Hy,
Here's bootup log:
Cisco 2821 (revision 49.46) with 118784K/12288K bytes of memory.
Processor board ID FCZ101372P9
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity disabled.
239K bytes of non-volatile configuration memory.
253008K bytes of ATA CompactFlash (Read/Write)
% Crashinfo may not be recovered at flash:crashinfo
% This file system device reports an error
Press RETURN to get started!
*Apr 8 11:13:27.187: %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x71
*Apr 8 11:14:32.827: %VPN_HW-6-INFO_LOC: Crypto engine: aim 0 State changed to: Initialized
*Apr 8 11:14:32.827: %VPN_HW-6-INFO_LOC: Crypto engine: aim 0 State changed to: Enabled sslinit fn
*Apr 8 11:14:35.191: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Apr 8 11:14:35.191: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Disabled
*Apr 8 11:14:35.903: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_open/read / code = 2595 (No device available)
/ bytes transfered = 0
*Apr 8 11:14:35.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Apr 8 11:14:35.911: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*Apr 8 11:14:35.911: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Apr 8 11:14:36.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Apr 8 11:14:36.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Apr 8 11:14:37.867: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Disabled
1. I wanted to load a newer IOS image and because it has 38mb I couldn't load by TFTP; I wrote down the image using a CF reader, router is booting up, but I receive this message: % This file system device reports an error
If I am to run: show flash, here's the output:
Cisco_2821#show flash
%Error show flash: (No device available)
2. Cisco_2821(config)#crypto engine ?
accelerator Crypto hardware device
aim Advanced Integration Module
onboard Onboard Crypto Engine
software Software crypto engine
What engine should I use, and what should I disable ?
3. What is best practice for an 2821 regarding installed memory, is it worth to upgrade to 512, or 256 will just be enough?
Kind regards,
Florin.
04-08-2009 04:47 AM
Hello Florin,
1) use FTP instead of TFTP and have the router to write the image by itself on the flash/CF it is the safest choice
2) probably AIM that should be present check with sh diag
3) follow the requirements of the new IOS image if it asks for more memory be prepared to install it
Hope to help
Giuseppe
04-08-2009 06:49 AM
Hello Giuslar,
1. I tried using an FTP server, but no luck as I was knocked out by some errors, and went out for the fast solution and copied it using a CF reader. Still in order to get rid of that error I have to upload that IOS by TFTP ?
2. I attached show diag output, which is gonna be, then ? the onboard one? I don't know which is best: AMI or onboard ?
3. Most of the IOS images require 256 RAM, but I was asking if it is any use of a 512 module?
Florin.
04-08-2009 09:47 PM
hello Florin,
I think, there's good chance of that, yes.
Could you tell me what are the IOS image and TFTP server?
And Could you post the "show version"?
Best regards,
Tomoyuki
04-08-2009 10:22 PM
Regarding the flash error, I can't upload anything via TFTP as the flash is no longer available:
Cisco_2821#show flash:
%Error show flash: (No device available); I did not format the CF, I just copied the IOS I wanted to run, and that's it.
As you can see in the attached file, I m running a Advanced IP Services version, instead of IPversion I had before.
As TFTP server, I tried with SolarWinds, first with an older version and then with the newest version find on their website.
About VPN Module, you see I have two, which of them should I be using?
Florin.
04-08-2009 10:37 PM
Depending on your ROMmon and or IOS (USB support starts from 12.4(4)), you can boot from a USB stick. I know I've done this several times.
ROMmon v12.4(13r)T (C2800NM_RM2.srec.124-13r.T) is described as "adds boot from USB flash drive capability".
Use the command "boot system usbflash0:
Note: "boot system usbflash0:", particularly the "usbflash0:" bit will not appear as an option so you need to enter the entire word in.
Have a look below:
Router#dir
Directory of flash:/
1 -rw- 30331404 Nov 12 2008 15:33:12 +00:00 c2800nm-spservicesk9-mz.124-3i.bin
64016384 bytes total (28999680 bytes free)
Router#dir usb
Router#dir usbflash0:
Directory of usbflash0:/
1 -rw- 34518464 May 14 2008 05:48:46 +00:00 c3845-advipservicesk9-mz.124-7g.bin
2 -rw- 1623191 Sep 5 2008 00:38:12 +00:00 C2800NM_RM2.srec.124-13r.T6
3 -rw- 18749384 Oct 27 2008 05:17:04 +00:00 c1841-advsecurityk9-mz.124-7g.bin
4 -rw- 20404320 Mar 7 2008 06:29:28 +00:00 c2800nm-advsecurityk9-mz.124-7g.bin
5 -rw- 1690523 Oct 3 2008 01:16:02 +00:00 C1841_RM2.srec.124-13r.T5
6 -rw- 34124956 May 14 2008 05:44:34 +00:00 c2800nm-advipservicesk9-mz.124-7g.bin
7 -rw- 21818492 Mar 1 2002 00:27:16 +00:00 c870-advipservicesk9-mz.124-24.T.bin
257187840 bytes total (123949056 bytes free)
Router#sh run | i boot system
boot system usbflash0:c2800nm-advipservicesk9-mz.124-7g.bin
Router uptime is 1 minute
System returned to ROM by reload at 22:57:24 UTC Mon Apr 6 2009
System image file is "usbflash0:c2800nm-advipservicesk9-mz.124-7g.bin"
DISCLAIMER: Use NON-Cisco certified USB/Compact Flash cards at your own risk. The author is not responsible for any use of NON-Cisco certified USB/Compact Flash cards incorrectly, inappropriately and will not take responsibility if your appliance(s) fail because of it. I was forced to use NON-Cisco certified USB/Compact Flash cards because my employer is a tight-a$$!
HAPPY EASTER!
04-08-2009 10:58 PM
My router is booting and running perfectly; it s just I want to get rid of that error, so if I will boot up from USB, will the error be gone?
04-08-2009 11:02 PM
Hi Florin,
Try upgrading the IOS to the next level up.
04-09-2009 12:02 AM
Thank you for your posting.
First of all, "AIM-VPN/EPII-PLUS" requires 12.4(T)
Take a look at following page:
Therefore, you can't use "crypto engine aim".
And perhaps you can't use "crypto engine accelerator, onboard and software" too by the IOS malfunction for any reason.
I'm sorry to disappoint you.
Tomoyuki
04-09-2009 01:24 AM
So what should I do? You recommend to update it to the T version ?
04-09-2009 02:16 AM
If you want to use your AIM/VPN card, yes you should.
04-09-2009 02:34 AM
Hello Leo
I didn't think of that.
It was a good lesson for me.
Tomoyuki
04-16-2009 06:10 AM
Ok, I have installed 12.4(11)T;
In my CF reader, I see the card with FAT file system; if I am to format to another file type you think it will work ?
What the default file type used on Cisco flash cards?
L.E. After the boot I still receive that error: This file system device reports an error.
I read smthg on google answer to this error, but got nothing, yet.
I tried to format it, from Cisco CLI, and here s the output
Cisco2821#format flash:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "flash:". Continue? [confirm]
%Error formatting flash (No device available)
03-19-2012 08:27 PM
I know i'm resurecting this post from the grave but I've recently ran into this issue and have found a solution to this problem. Hopefully this will help others with the same issue.
Initially i thought the flash cards were bad however i knew they wernt. 3 flash cards dont go bad at the same time. I noticed my problem being tied to a downgrade from 12.4(24)T to 12.4(15)T
The router acted as if the flash was not there, gave me errors and couldnt format/erase it.
I took the card out and put it into the PC than formatted it with NTFS. Than reinstalled it back into the router and the router than was able to see the card. Formated it than from the router cli and was able to http/ftp an image onto it and reload it and it worked just fine.
I'm not for sure if this is a Cisco issue or if its a windows issue causing the FAT to mess up when writing new filese to the file system on the flash card. Hope this fixes you're guys issue.
