06-09-2010 06:39 PM - edited 03-06-2019 11:30 AM
i recently bought a catalyst 2924 XL on craigs list (easy solution to what i needed), but the person i bought it from doesnt know the enable password on the console line, is there a way i could grab it or reset it??
need some help on this, Thanks.
Solved! Go to Solution.
06-09-2010 06:49 PM
Hi Nate,
Just follow this link for password recovery procedurefor for Cisco Cat switches
Reza
06-09-2010 06:49 PM
Hi Nate,
Reza
06-09-2010 06:53 PM
this will wipe the config or reset the config or pass?
06-09-2010 07:03 PM
You can keep the current config but I would just wipe it and start fresh since this is new switch to you
06-10-2010 05:16 AM
i went to rename the config, it renamed, then i tried deleting the config.text left over, but the permsisions are read only, there a way i can delete the config file or format the config file/what i need to format to clear out the current config
