2924 CL Switch - Telnet Access
cpremo
I'm able to access the remote switch via HTTP. However, I can't access it using HyperTerminal. My PCs IP is in the "ip http access-class 2" Access-List.
Here is the VTY setting on the switch. Any Ideas???
line con 0
exec-timeout 0 0
transport input none
stopbits 1
line vty 0 4
access-class 2 in
exec-timeout 30 0
password <Removed>
login
line vty 5 15
access-class 2 in
exec-timeout 30 0
password 7 <Removed>
login
transport input telnet
6 Replies 6
John Blakley
Does it work if you remove access-class from the line? Can anyone else telnet to it that's in the list?
HTH,
John
HTH, John *** Please rate all useful posts ***
I'll give it a try. I'll remove it from both vty 0 4 and vty 5 15.
Here is what is showing on the Configuration now and still no luck accessing the device using HyperTerminal. I get the following error: "Unable to connect to XXX.XXX.XXX.62 port 23". My "HT" emulation is Auto detect.
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
exec-timeout 30 0
password
login
line vty 5 15
exec-timeout 30 0
password 7
login
Leo Laohoo
Try using the DOS command "telnet" instead of using HyeperTerminal.
Tried that and the same results.
Leo Laohoo
Have you tried other machines? Could be a firewall.
