Webcast-Catalyst9k
2924 - switch#show Ip
When I type this command in by using hyperterminal I get the Ip address of 1.
Can anyone explain to me why? I am new in the cisco world and could use your help.
Lon
Re: 2924 - switch#show Ip
can you make your question more brief?
can u paste the output of the command plz
When doing the command "show ip" on a layer 2 switch it shows the number of the management VLAN as illustrated below (which should be 1 by default, any way try changing it as follows):
SW3#sh ip int brief | i VLAN
VLAN1 unassigned NO unset up down
VLAN13 1.1.1.1 YES manual up up
SW3#sh ip
13
HTH,
Mohammed Mahmoud.
Thanks a bunch,
From your reply I was able to figure out how to change the ip address, but unfortunately when I turned it off it went back to the orginal. I tried to run the command: copy running-config startup-config, but it did not like it. I have a cisco book and have passed the CNA 5 years ago, but I forgot all of it because the lack of having anything to play with. Is there a place to go to find proper commands for certain devices? Do you know the command I need to save my changes for this 2924 switch? The total memory is not quite 4mb if I am reading this right. Is that what you see?
This is what I am looking at so far:
Switch-4385#show memory
Head Total(b) Used
(b) Lowest(b) t(b)
Processor 45FF1C 3801316 1749908 2051408 1778828 1773128
I/O 70000000 1048576 606784 441792 328436 425692
Switch-4385#show ip
Switch-4385#show ip interface brief vlan1
Interface IP-Address OK? Method Status Prot
ocol
VLAN1 10.0.16.9 YES NVRAM up up
Switch-4385(config)#interface vlan1
Switch-4385(config-if)#ip address 10.0.16.1 255.255.255.0
Switch-4385(config-if)#exit
Switch-4385(config)#exit
Switch-4385#
Switch-4385#show interface vlan1
VLAN1 is up, line protocol is up
Hardware is CPU Interface, address is 0002.b977.e440 (bia 0002.b977.e440)
Internet address is 10.0.16.1/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Last input never, output 00:00:50, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
9 packets output, 576 bytes, 0 underruns
0 lost carrier, 0 no carrier
Here's the link to Cat 2900 switch configuration guide.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc6/scg/scg.html
Sundar
Now I have some studing to do.
Have a good day!
Lon
406
