2948G OS?
I have an old 2948G with 48 10/100 and 2 fiber ports. I cant seem to find any direct reference to any software for it. I am curious if I can migrate it to IOS or at least update the os.
WS-C2948 Software, Version NmpSW: 7.1(2)
Copyright (c) 1995-2002 by Cisco Systems, Inc.
NMP S/W compiled on Feb 7 2002, 16:53:43
GSP S/W compiled on Feb 07 2002, 15:24:55
System Bootstrap Version: 6.1(4)
Hardware Version: 2.5 Model: WS-C2948 Serial #: JAE0604013W
Mod Port Model Serial # Versions
1 0 WS-X2948 JAE0604013W Hw : 2.5
Gsp: 7.1(2.0)
Nmp: 7.1(2)
2 50 WS-C2948G JAE0604013W Hw : 2.5
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 34197K 31339K 12288K 7257K 5031K 480K 271K 209K
Re: 2948G OS?
Hi Friend,
This switch cannot be upgraded to IOS but for sure you can upgrade to the latest CATOS which is 8.2GLX
Also the CATOS for this switch goes on the same train with base image of CAT4000 switch.
Just check this link and you can read the release notes for the same
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/8_2/index.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_4502.htm
Ankur
*Pls rate helpfull post
Purple
Re: 2948G OS?
This was a good switch , it is catos only and runs catalyst 4000 code . You can either use the latest in the 8.X train or use 7.6.12 or above (latest is like 7.6.18 I think) in the 7.X train which is considered "general deployment" code .
349
